So, I ordered a ton of components when I first got drawn into this hobby and by now I've got a good handle on most parts I've needed for my projects but these weren't labeled when I received them in the mail and now I'm not sure what they are. I'm sure I'll end up needing them eventually but I haven't yet. Anyone who can clear this up for me?
(https://i.postimg.cc/w1fL1dFV/AD86547-E-40-A9-4-AE0-AD5-A-50939-A341-DB1.jpg) (https://postimg.cc/w1fL1dFV)
(https://i.postimg.cc/m1sFvZ2b/E934202-A-026-E-4-FD6-AD6-A-55-B4-D17-CF3-E6.jpg) (https://postimg.cc/m1sFvZ2b)
almost certainly diodes... use a meter with a diode test and determine the voltage drop...
The top ones are measuring in the range of 764-770, the others are measuring around 662-666.
Quote from: HighSolstice on February 24, 2020, 10:40:54 PM
Assuming that's mV, I'd say Silicon diodes.
+1 on two varieties of silicon small signal...
You would want maybe to eliminate things like zener. I'm not sure what the best way to check for a reverse breakdown voltage... you would not have ordered zeners with reverse voltages over say 9.1? I don't think common small signals would be burned out by reverse-biasing them with 9v? And if you did ruin one or two, not so terrible a loss.
The diodes are often identifiable from the package *AND* the color of the bands. Different packages with the same colored bands are different so you need to match both.
* First diode:
DO-34 package
Cathode band = yellow
2nd band = yellow
Possible match is the Panasonic MA2C858, MA858
http://pdf.datasheetcatalog.com/datasheet/panasonic/SKG00003BED.pdf
There may be other diodes with the same colors.
* Second diode:
DO-35 package
I haven't search for this one. (It's unlikely to be the common 1SS133 as that has a DO-34 package)
EDIT: maybe this (used in BOSS pedals)
1s2473
http://www.datasheets-pdf.com/1s2473-%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88-diode/
I agree the bottom ones look like 1S2473s. Frequently used in early Boss OD-1 and SD-1 overdrives. Though never used by Ibanez AFAIK, they are one of my favorite for tube screamer clippers, paired with the JRC4558. They have their own sound, very smooth, try 'em out.
