Is it possible to take something like the Deep Blue Delay and split the dry and wet signals to separate outputs by skipping the mix pot and having two outputs?
Basically I want to experiment adding other effects to each signal separately. For example, a vibe to the original signal and a fuzz to the repeats?
Yup.. 8)
excellent, thank you
you might want to experiment with adding some FX loops. i suggest a clean path loop, a pre-delay loop and a post-delay loop, so you can still use the internal mixer.
