DIY Stompboxes => Building your own stompbox => Topic started by: Subropontes on September 20, 2021, 06:38:22 PM
Title: Troubleshooting silicon Tone Bender
Post by: Subropontes on September 20, 2021, 06:38:22 PM
Iím fairly new to building pedals and Iím learning a lot here.
I am having issues with this silicon Tone Bender and Iím struggling to figure out whatís going on.
I get signal when the effect is bypassed but not when the effect is on, but I get some signal when I touch the back of the board which makes me think that is ground related. I have the boardís ground wired to the input jackís ground, the jackís ground wired to the switchís ground and the batteryís negative to the inputís ring. I checked continuity and the board, jacks, pots and switches are all grounded. I double checked the connections and everything is fine, there are no bridges connecting strips and all the cutouts are doing their jobs.
What am I missing? What should I check next?
(https://i.postimg.cc/MMwX9bty/29-F1-D1-A6-CE0-A-4-DA0-ABA8-06-D28-D3-C9-A30.jpg) (https://postimg.cc/MMwX9bty)
(https://i.postimg.cc/m12ksLvk/9-CF0-B47-B-D6-D8-4-B87-97-BA-A2-C9-A37235-F1.jpg) (https://postimg.cc/m12ksLvk)
(https://i.postimg.cc/phBr4h13/BF1-AF6-DC-1-E25-44-CA-8-F06-364-F1-FD5-BF8-B.png) (https://postimg.cc/phBr4h13)
https://youtu.be/IJs0yqFdNp0
Title: Re: Troubleshooting silicon Tone Bender
Post by: GibsonGM on September 20, 2021, 08:16:32 PM
Welcome to the forum!  Let's see if we can get you started troubleshooting this.
1) go here and check out the proper way to wire it all up, first, just to be sure you have it right.  There is a pdf file you can download and keep for reference, everyone should have this.
http://www.tonepad.com/project.asp?id=35 (http://www.tonepad.com/project.asp?id=35)
2)  If you get no results from the wiring check, provide the info asked for here and we'll try to help:  https://www.diystompboxes.com/smfforum/index.php?topic=29816.0 (https://www.diystompboxes.com/smfforum/index.php?topic=29816.0)
Usually the answer is found :)  Might take a little time, so hang in there.
Post by: antonis on September 21, 2021, 03:23:34 AM
Hi & Welcome, also.. :icon_wink:
>I have the boardís ground wired to the input jackís ground, the jackís ground wired to the switchís ground and the batteryís negative to the inputís ring.<
What about output jack's ground..??
P.S.
As far as I can see, you use painted enclosure so be sure about out jack grounding by wiring its sleeve to any convinient ground point..
Post by: GibsonGM on September 21, 2021, 05:04:55 AM
^  Exactly this.  I wanted you to review your switch & jack wiring to make sure you are using the right grounding points.
The risk of a ground loop from using a ground wire on the output jack is pretty minimal at such low voltage. If the jack ever comes loose, it's a horrendous racket, too!
Post by: Subropontes on September 21, 2021, 11:24:14 AM
P.S.
Thank you!
I do have the output jack grounded to the inputís jack ground.
I changed the offboard wiring yesterday (still have the same issue) and I donít have the photo from before but this is what I had (this is the wiring I usually use) with the output jackís ground wired to the the inputís ground:
(https://i.postimg.cc/WFntQRFS/E9-B9-A4-DC-B4-A4-4-ECB-BE97-682-E024031-D5.gif) (https://postimg.cc/WFntQRFS)
And yesterday I changed to this one, which is the wiring the first post recommended and I decided to give it a go, just in case it was an offboard wiring issue:
(https://i.postimg.cc/yk9CdmnC/F2-A53-E23-F007-4-CD9-B002-59172-CEBCABF.jpg) (https://postimg.cc/yk9CdmnC)
Post by: GibsonGM on September 21, 2021, 03:15:37 PM
Ok, so you still get signal when bypassed?  If so, time for the debugging page I linked to in "2)" of my first reply to you!
Eventually you'll need this no matter what, so here is something to build after you post the debug info back here.  http://diy-fever.com/misc/audio-probe/ (http://diy-fever.com/misc/audio-probe/)
Post by: Subropontes on September 22, 2021, 12:39:14 AM
Yes, as I mention in the first post it works when the effect is bypassed, it doesnít when the effect is on but I get a little bit of signal when I touch the back of the board.
Iíve built another one using the exact same layout and I had a similar problem, I get sound but only if I play the low E and itís super farted like itís really underbiased but if I touch the back of the board I get signal with fuzz and it reacts normally to the knobs and it sounds decent.
Can both be just a bias issue? Why would it works differently if I touch the back of the board?
Both of them have basically the same voltage, hereís what I got:
The one with farted low E that works semi normal if I touch the back:
Q1 C 6.7, B 1.4, E 0.49
Q2 C 1.52, B 0.62, E 0.5
Q3 C 4.22, B 1.53, E 0.92
Video:
https://youtube.com/shorts/4NwIIA4nOHE?feature=share
The one that has no signal and it gets some signal if I touch the back:
Q1 C 6.59, B 1.5, E 0.50
Q2 C 1.53, B 0.63, E 0.4
Q3 C 4.03, B 1.52, E 0.92
Video:
https://youtube.com/shorts/IJs0yqFdNp0?feature=share
Post by: antonis on September 22, 2021, 07:03:10 AM
100nF greenie cap hides the existence(?) of 1N914 diode..
In case of it is there, try to short it (solder a small piece of wire on its legs) and see what happens..
Post by: aleks_tedstone on September 22, 2021, 07:15:09 AM
Have you tried to adjust the trimpot through its full range? I know this seems like an obvious question especially as you have mentioned transistor bias yourself, but if you have some signal then this might be the key to at least fixing the one you describe as working 'semi-normally'. In the video clip it does indeed sound very gated, it might be that your finger can provide enough conductivity to properly bias the transistors.
The other one seems to work well as a radio, so its clearly amplifying something... This may need more extensive debugging as per GibsonGMs suggestions.
As you have socketed the transistors you could pop them out, measure the hfe and check that it is appropriate for each position, as this a lot of other forum threads discuss, the circuit can be quite sensitive to the actual values of these components, and how you bias them, and their leakage.
Post by: antonis on September 22, 2021, 08:18:18 AM
Actually, it rectifies something prior to amplification.. :icon_wink:
Post by: Subropontes on September 22, 2021, 11:15:21 AM
Thank you!
Iím not sure if I know what you mean. Could you explain it?
Post by: Subropontes on September 22, 2021, 11:23:08 AM
Yes, I did. If I have the trimpot all the way up is when I get that gated sound coming through, anything less than that I get no signal which makes me think that is a bias thing but the voltages Iím getting on both donít sound too far off (as far as Iím aware with my basic knowledge) so I donít know.
I only socketed the transistors on the one that I have no signal at all. I have 3904 on Q1 and Q2 and a 5088 on Q3 for both. I tried all 3904 and all 2222a and still had no signal. I didnít try all 5088 so Iíll give that a go because why not.
Post by: antonis on September 22, 2021, 11:45:59 AM
This.. :icon_wink:
(https://i.imgur.com/WFoiOhE.png)
Post by: GibsonGM on September 22, 2021, 12:41:37 PM
I'd try antonis's suggestion, it is a quick test.   If that does nothing, I'd then use my audio probe to see where the signal degrades (after removing that jumper).
While playing a note, Audio Probe Collector of Q1...base and collector of Q2.  Somewhere in there the signal should go from 'normal' sounding to crap, that may tell something.  Voltage at Q3 collector is 4.03, close to the nominal 4.5V, so bias could make it SOUND a little off, but it seems that it should WORK at this point, barring a bad connection or bad part, etc.  Even better, try to dial that to 4.5 with the pot before probing, if you can.   Don't short out anything while you probe :)
There could be a solder bridge or cold solder joint making a bad contact, for one thing. Since you do have signal at output, it's probably nothing huge, just that you have to find it!
Post by: Subropontes on September 22, 2021, 01:29:31 PM
Thank you for all the tips! Iíll check for cold solders and reflow everything that looks dodgy, if that doesnít work Iíll try Antonisí suggestion and if that doesnít work Iíll put them in a drawer and move to other projects to get some sort of gratification before going back to troubleshooting these. Haha
