Just wondering is it possible and or practical to mix both inverting and non inverting op-amps from within the same IC casing, both running from the same vref bias voltage supply? Like for instance if there were 3 inverted op-amps and 1 non inverted all within a TL074
Is this feasible when all are running from same voltage and vref bias? or even if the 3 inverted had there own vref bias and the non inverted had a separate bias vref, is this possible or practical? Thanks
An op-amp is an op-amp. That you have four or two in a single package is just a convenience, but irrelevant. The op-amps don't know. You can wire them up as inverting or non-inverting amplifiers (or comparators, or integrators, ...) as you wish. Sharing VREF is also irrelevant. To the op-amp, it's just a voltage. It doesn't know what you're using it for.
Thanks BlueBunny, I think that clears things up a bit, Cheers.
