lots of people use an input cap switch with fuzz faces, rangemasters...
but then there is the setup with 2 caps and a pot inbetween like the deluxe bazz fuss.
how do these 2 systems compare and is there an advantage in using one or the other?
Quote from: birtlots of people use an input cap switch with fuzz faces, rangemasters...
>>>Starting with the 'large' value, then [switch] seriesing another value
with it at the input wire [that goes to the BPSwitch] is very easy and requires only an SPST to go across the offboard cap.
>>>Adding passives to the input causes some loss.
One makes it easy to dial in [the pot method] the other is very easy to impliment, on or off the board.
