This is my newly designed pedal schematic. It gives a pretty mean distortion when cranked, and a good strong regular OD when turned down. Tell me what you guys think if you build it. I've put about 3 hours of play time on mine.
(http://cordova.asap.um.maine.edu/~raymondj/imagehost/5thgearod.jpg)
1. 1N914 simply shunt LEDs, so LEDs are absolutely "closed" all the time. Fell free to cut the LEDs out of the cicuit.
2. Two similar trannies in parallel - why? To have more noise? One BJT is enough for the circuit.
3. Put 5k pot in emitter of Q1 Instead of R1 500k pot in the input path - it will give you less noise and more posibilities to vary sound coloration.
I tried having a 5k linear pot off the emitter of Q1 and didn't like how it shuts down the circuit around 1/4 turn of the knob...I think this could be solved by connecting lugs 1 and 2 together though. As far as the LEDs go, it gives it a stronger sound, more grunt. I'm no electrical engineer, so I couldn't tell you why. I just like it. And as far as having two trannies in parallel, I did it because I thought it was an interesting idea and I hadn't seen it done before.
Quote from: DDD on January 13, 2006, 12:59:47 PM
I believe that MPSA13s are Darlingtons. IIRC, they are BJT as you state. The gain on this thing must be outrageous!
Quote from: David on January 13, 2006, 02:11:02 PM
It is ;D
Joe, how's this circut work with other trannies like 2n50xx? Or will it? I don't have anything in my parts bin but 2n5457's and 2n5089's :icon_cry:
Sounds like a real screamer!
Should work fine with the 2n5089s, I haven't tried it yet though.
holy hell. a one resistor circuit. is nayone else seeing this!!?? :icon_lol:
that's actually really cool. it looks liek it would have a decent amount of distortion, so i might slap one together.
Cool, I'd love to have some other people put them together, its an easy build and has tons of usable distortion. Or at least I think so. Of course I've really only played it with 2 different guitars and one amp...the amp being a dean markley k-20 and the guitars being a Hamer "strat" and a Lyon LG-4.
Joe, I breadboarded it last night and used the 2n5089's. It's a cool distortion/fuzz sound, but I get alot quick decay and splatter when letting single notes ring out... Any idea on the voltages for each pin? Joe, do you get the splatter with the trannies you are using?
I goofed around with it a bit. I sub'd the led's with 1n914's and also bypassed the 1st diode section. I agree with you joe, the sound of the extra diode section sounds good. Nice work, Joe.
Chadd
It might just be the 2n5089s. When I had only one diode in each section I got poor decay, after I added in the second one in the opposite direction, it was fine. I would check and make sure you have one going each way. Also, if you turn down the guitar's volume too much, or the 500k audio pot too much, it will have crappy decay.
Awesome that (for the most part) you like it!
Congrats !!
Well it doesn't "look" right, but it works for me :icon_eek:
Has to be MPSA13 though, nothing else seems to work "right"
The darlington arrangement "somehow" makes this work and it's
quite a "high gainer" from HB equiped gtr !!
MODS :
You dont need the input pot, gtr vol works fine here, I just placed a 1M to ground here and
also used 33n I/O caps, with a small roll off cap off Q2's collector - 2n2
this just lost the "fizz" for me and is fine.
The LED's dont seem correct, but without them it's a different type of crunch ?
Cheers,
Marty.
EDIT :
Voltage reading for both Q1/Q2
C 1.26
B 1.12
E 0.00
Putting transistors in parallel should DECREASE noise (ignoring what may happen because of changed input impedances) because, the signal adds at each output, while the noise (being random & independant on each transistor) cancels to some extent.
The back to back diodes must give some interesting distortion (think of the bias changing with the signal level..).
I don't personally think the doubling would do much, but I guess it is up to people who build it to say!!
Congrats, unless we get more weird stuff tried out, there isn't anything new going to turn up.
Well, you can "remove" either Q1 or Q2 and it works 98% as well as with both !
If you leave just Q2 in place, Dist seems a tad softer
If you leave just Q1 in place, there's a tad more "hard spank" to the Dist ....
So, make it with one MPSA13 and switch between diodes :D
In both these cases the LED's and the 4148's are still in circuit ... ???
WIERD ?
MM.
Wow, this is great stuff guys, good to here you are trying out my stuff/modding it. I've been thinking about ditching the input pot, its not amazingly effective anyway. And thank you Paul, I purposely did something strange/out of the norm just to see what would happen, and it came out pretty cool. I just wanted to add a little something to the community, and when I came up with this, I had to share. Now I'm going to have to try some of your mods on my pedal ;)
Wow!
Actually weird thing!
NICE!!! I just threw it together on a breadboard and it sounds great, good stuff Joe!!
I didn't use the pot on the input but added a 1M resister from the input to ground before the input cap which i changed to 0.033uf other than that is as per your schem.
I'm gunna try some other mods then it's off to the perf.
Maybe add a 3way switch ie. Q1 on Q2 off, Q1 off Q2 on, Q1 & Q2 on?
pyrop ;D
Thanks pyrop. I haven't tried it with .033uF caps, but I did try it with .1, .047, .022, and 0.01. The difference between 0.047 and 0.022 was relatively minor, but I liked the smaller cap sound.
Good to see people actually building this, I figured a few people might look at the schematic and comment, but to actually have people build it is a big thing for me :-) And the fact that you guys like it helps too!
I'm working on designing a metal effect, but so far only have it sketched out on paper. When I finish drawing it and test it a little I'll release that schematic too.
Quote from: Joecool85 on January 17, 2006, 11:24:50 AM
I would re-draw this as a 1 transistor version, use two 1N4148's ( like second stage )
Having played wirh it for a while, this is about 98% of the sound, with half the parts
That makes a quite special "tiny" circuit, you could fit it in almost any small box !
Cheers,
Marty.
I might redraw it as that for a simple version, but I like the full version, it just don't have the same bite with one tranny (to me.)
Also, did you use 1n4148s? I had listed using 1n914s in my schematic, so I'm not sure, maybe those sound different.
I agree with DDD on this, but you can make both stages assymetrical, for a semi conductor/diode input clipping circuit... This is really half a push pull, but may work well if you add a little bias to the Q2's emmiter.
If I may suggest since there is no bias and both are in paralell, try this
ditch the input driver control, add 1K series resistor (optional), take LEDS out of first stage (D1-D2) and add 470K resistor from collector to base (feedback), keep the diodes in the second stage, add 470K resistor from collector to base and add 100ohm resistor on emitter to ground. You can also try a cap with 100ohm, like a 1uF to fatten it up (adds noise and highs too)...
This makes Q1 fully saturated, but stable and turns Q2 on more= assymetrical semi conductor clipping...
Try this and let us know how it sounds, post the voltage bias on each pins too please.
The Pedal Nazi
Scotty
Unfortunetly I have very little time for it now, I just started spring semester. If anyone else wants to try, have it at.
what if you would make this a pedal with 5 stages, and 5 switches, each adding that little something extra
and actually name them 1st gear, 2nd gear...
later on you could switch between them with a real "acceleration poker" from your car
LOL i doubt if that word is correct, i don't know it in english though so i let babel fish take care of it...
argh you know what i mean right? :D
It is an interesting idea, however I doubt I would encorporate it into a single pedal. What I might do is put it into a huge box with several other pedals as a custom build multi effects box. And I believe you are looking for "gas pedal" or "accelerater pedal".
So...out of curiousity, how many of you guys built it? Anyone box one up? Make it to the pedal board? :o
I still have some tweaking to do on it, mainly just figured out what I want to do with gain control on the beast. I'm unsure as of yet.
Quote from: Joecool85 on January 13, 2006, 12:41:16 PM
hi,
it's a great project for a newbie breadboarder and it sounds great too.
this is my attempt to modify it (i.e. randomly replacing components while doodling with a guitar).
https://www.dropbox.com/s/1am5yp5sho8a1zc/6th%20gear.png?dl=0
it sounds a bit louder and the overdrive is less compressed. no pots added, i like to keep things minimal.
R1 / R2 are misplaced accidentally, but the circuit still works.
i've boxed it for a friend and it's dead quiet too.
regards,
george
