Hi fellas,
I'm planning on building a power supply for a pedal board and came across this vero layout from somewhere (can't find the original link).
http://photobucket.com/albums/e310/billymill54/?action=view¤t=PSU.gif
For this circuit do you just use a standard 12vac wall power supply (and does this need to be hardwired or could you connect the 12vac wall power supply via it's 2.1mm jack into a 2.1mm socket on the multi-power supply enclosure)?
Cheers
Quote from: jimmy54 on February 19, 2006, 05:38:55 PM
Cheers
as long as the socket is isolated from the chassis, yep.
I'm making similar thing too for both 9V and 12V
http://storm-software.co.yu/diy/index.php?project=stuff (http://storm-software.co.yu/diy/index.php?project=stuff)
