Projects => Beginner Project => Topic started by: jtzim07 on September 28, 2006, 12:07:35 PM
Title: are these parts ok?
Post by: jtzim07 on September 28, 2006, 12:07:35 PM
hi, im new to this and want to build the beginner pedal
here are the parts im thinking of buying, are these ok?
-0.1 uF Metallized Polyester Film Capacitor
----This 0.1F 250V 10% metal-film capacitor can help you with many of your electronics projects. 250 WVDC. Low leakage. Stable at high temperatures.
-10F 35V 20% Radial-lead Electrolytic Capacitor
----This 10 microfarad 35V 20% radial-lead electrolytic capacitor can help you with many of your electronics projects.
35WVDC Operating temperature: --40 to +85C
-22 uF Electrolytic Capacitor
----This 22 microfarad 35V 20% radial-lead electrolytic capacitor can help you with many of your electronics projects.
-47F 35V 20% Radial-lead Electrolytic Capacitor
----This 47 microfarad 35V 20% radial-lead electrolytic capacitor can help you with many of your digital electronics projects.
-10K Ohm 1/4-Watt Carbon Film Resistor5 Pack
----10K ohm, 1/4-watt, 5% tolerance carbon-film resistors sold in packets of 5.
-100K Ohm 1/4-Watt Carbon Film Resistor 5 Pack
----100K ohm, 1/4-watt, 5% tolerance carbon-film resistors sold in packets of 5.
-47K Ohm 1/4-Watt Carbon Film Resistor 5 Pack
----47K ohm, 1/4-watt, 5% tolerance carbon-film resistors sold in packets of 5.
-2N4401 NPN Switching Transistor
----Time for a switch? Then check out this transistor. The NPN Switching Transistor has a power dissipation of 350mW. Mfr. #2N4401. I(C) Max: 600mA.
-5K-Ohm Linear Taper Potentiometers
----Control the power on your project with this 5K-Ohm Linear Potentiometer.
Wattage rating of 0.5W
Tolerance 20%
1--11/16" (6mm) shaft
Mount in a 5/16"-diameter hole
i included the product descriptions because i thought it might help. please tell me if these parts are ok before i begin this project. the thing that i am unsure about is the npn transistor, because the parts list says 2N5088, but i cant find those.
thanks!
Title: Re: are these parts ok?
Post by: aron on September 28, 2006, 03:39:42 PM
See if you can get a lower voltage  .1uF cap. Higher voltages will be larger in size. It may not be too big, but you never know. (It should be ok).
See if you can find: 2N3094, 2N2222
Aron
Post by: ubersam on September 29, 2006, 01:51:29 PM
I used Cornell-Dubilier (CDE) DME type poly caps which were pretty small (0.1uf is 10mm wide) even though they were rated for 250V. The Vishay Orange Drops on the otherhand were pretty huge, easily twice as big as the CDEs. The CDEs cross reference Panasonic ECQE types (which I think are the ones available through smallbear).
For the transistor, I prefered the results using MPSA18.
Post by: jtzim07 on October 03, 2006, 01:34:56 PM
i cant find any other transistors in town, so what would the effect of a different transistor have?  size is not an issue to me, so will the higher voltage still work?  size is not important for my first project
Post by: aron on October 03, 2006, 03:31:07 PM
You can order transistors from the STORE link above as well.
Post by: jtzim07 on October 04, 2006, 10:20:05 AM
i cant order anythign online, i dont have a credit card. i was wondering if there were any other transistors that would work so i can actually do this project. i wanna buy locally
Post by: aron on October 04, 2006, 01:07:07 PM
Go to your local parts store and give them these numbers:
2N3904 or 2N2222 and ask for a substitute part.
That's what I used to do.
