in the old thread on this topic it said to simply make 2 and wire the v+ and v- together, but what about the rest of the leads? where would they go in the socket. do they all just share the conections?
____
Ground -I I- ?
+in -I I- ?
-in -I I- ?
out -I_____I- v+/v-?
Lookup the pinout for the opamp you are going to replace.
You'll have an inverting and a non-inverting pin for each opamp, and an output for each.
For instance, there's a connection diagram for a TL082 opamp (which matches most dual opamps used in pedals ?) here:-
http://www.national.com/mpf/TL/TL082.html (http://www.national.com/mpf/TL/TL082.html)
thats perfect thanks
