A simple fuzz idea that uses crossover distortion combined with transistor saturation in order to achieve what "should be" a unique fuzz sound. This is an untested idea, but the values should be close. If there is too much "splat", then you should be able to put a resistor (maybe 100k-220k-ish)after the 1N34a diodes to limit the second transistors over-saturation. Anyway, if you breadboard it, report back on your findings...
(http://www.freewebs.com/soulkitchen/X-OVER%20FUZZ.GIF)
Diode section
Look at the boss HM2 schematic
Quote from: Gus on July 08, 2008, 03:00:45 PM
Diode section
looks like boss is combining diodes to ground as well as diodes in the same type setup as above (as well as in the feedback loop of a op amp)
Any particular reason for the 10k's on either side ?
(http://www.freeinfosociety.com/electronics/schematics/audio/pictures/bosshm2.gif)
Anyone still has the schematic?
I've lost mine...
