I have just built a polyphonic MIDI synth using a computer soundcard as the brain (more info on that project later, it's really fun).
In order to access most of the sounds in this thing, I need to send a sysex message. But the whole reason I built this unit was to have a physical keyboard that's not part of my computer, so I need a hardware box that can send this one measly sysex message when I hit a button.
I happen to have a bunch of PIC 16f684s laying around, so if it would be possible to use that chip, that would be great.
What would I need to do to write a program that just sends this one message? Are there any code examples similar to this that I could dig through and adapt?
There are reams and reams of stuff. Thorsten Klose's "Floorboard" (although that was written for a 16f874) comes to mind.
Another example is an adaptation that Josh Harle made to bit-bang serial output of a MIDI note number at 4MHZ so he wouldn't have to use an external clock. I think that used a 16F684. The point of that is that it's a very short leap to formatting and sending SYSEX messages.
THIS SITE[\url] has a couple of assembly transmitters for 16F84s. I'm sure you could easily modify them for a 684.
Gabriel (http://www.audiomulch.com/midipic/)
hi
Once you've tried a PIC with an integrated UART, it's a pain to go back to software UARTs... I would recommend to use something like a 16f88 or a 16f628. I've recently programmed a MIDI controller that uses sysex to communicate with a PC, so I could help if needed.
But when stepping into programming the serial interface and consider all timing issues associated to it, I'm a noob...
Regards,
Potul
dont know if this helps...been looking at building midi drum kit with transducers...
rob.
http://highlyliquid.com/midi-controllers/ (http://highlyliquid.com/midi-controllers/)
