In addition to the version 2 dd-3 that i have, i also have a longchip version of the pedal from 1990.
Now it works fine however it's missing the delay potentiometer.Now i've had the backs off both dd-3's to compare and they both have different types of pot but i know the value of the missing one ( 10ka rk097111) .Where's the best place to get a replacement from?
Any 10KA pot will work fine as long as the physical size will fit the enclosure
That is a 10k audio pot or logarithmic. Just is case you didn't know! ???
Thanks for the replies.
I've emailed roland as i cant seem to fine one that small to fit the casing.
You can check with Steve at Small Bear.
http://www.smallbearelec.com/home.html (http://www.smallbearelec.com/home.html)
smallbearelec@ix.netcom.com
One of these maybe?
http://www.smallbearelec.com/Categories.bok?category=Potentiometers+and+Trimpots&searchpath=3796603&start=17&total=40 (http://www.smallbearelec.com/Categories.bok?category=Potentiometers+and+Trimpots&searchpath=3796603&start=17&total=40)
Thanks for the replies - got one coming from roland for 3 pounds plus vat and post,not bad that. :)
