61
Building your own stompbox / Re: Yellow humper correct schematic
« Last post by aron on Yesterday at 02:03:22 AM »The purple peaker was my secret weapon with a Pignose 150R. I put it in the effects loop and it sounded great!
I found a photo of a WD-era Yellow Humper which I strongly suspect (based on previously trying to work out the PCB layout of a Purple Peaker) has two 1M resistors in the locations where the 470Ks would go according to the schematic (the two that are nearest to the viewer):Good digging.
Otherwise, visible resistor values seem to be as per the schematic (15K, 33K, a couple of 39Ks, a 150K on the right side where I suspect the input to be). Not a whole lot to go on, but a bit more grist for the mill.
(Oh and that Purple Peaker PCB appeared to have BC183LCs rather than 2SA666s, for what it's worth...)
IC 1 reads:To me the part of the circuit around pin 5, 6, 7 seems to be working and that VB would appear to be at 2.0V.
IC1
Pin 1: 8.12v
Pin 2: 2.40v
Pin 3: 2.30v
Pin 4: 0v
Pin 5: 1.99v
Pin 6: 2.00v
Pin 7: 1.96v
Pin 8: 8.61v
in a page of photos, any chance of a pic of those caps?
Why do you need to fill in six checkpoints for each post here?it will pass with time.
Choose words, write letters? It's inconvenient.
A Ling ?
Chuck Berry - My Ding A Ling (1972)
The man refined and developed rhythm and blues for 70 years, and he is remembered for singing a dumb ditty about his wee-wee. (This was his only #1 hit, and next-to-last top 40.)
much much longer version
Did he play through speakers with Whizzer cones?A Ling ?
