Craig Anderson pre-amp not working diode heating up
Started by Isg1315122, March 10, 2018, 01:41:19 PM
Isg1315122
I'm pulling my hair out here. I've built and rebuilt this circuit. At first I didn't realize it was bipolar. I was only using one battery.
Now I rebuilt it to be sure and I hook it up. One of the leds in the clean / dirty loop light up when the switch is off.
The +v in diode is heating up and I'm at a loss.
In the mods it says I don't need a bunch of stuff because I'm not using a vu meter only for guitar. So no xlr no +out just - out and pad A is for low level inputs again not needed.
Some questions: on the B sides of the open amp ic2b it has pin 7 and 14 common to the center of c10 and d4,
Pin 14 is the -supply which goes connects to pin 7 which is + supply. Am I missing something cause that seems to be mixing polarity the same goes for ic1b pin 7 and 14 are common and I don't see why.
2nd if r3 -5 and c7 aren't needed do you connect pin 13 to pin 8?
I thought that you would to normalize that output.
Is there something I'm missing? Would a pic of the bread board help anyone?
RickL
The schematic is mislabelled. The positive supply goes to pin 14 on both op amps and the negative supply goes to pin 7 on both op amps. Craig's layout in the book is correct.
Tubebass
#2
Anderton used 4136 quad op amps IIRC, which have a totally different pinout.
Edit: Not quad, 14 pin DIP dual.
More dynamics????? I'm playing as loud as I can!
Isg1315122
Quote from: Tubebass on March 11, 2018, 03:17:02 PM
I'm aware of this and have the conversation written down but in the schematic it shows even with the original pins to be hooked up incorrectly.
