NEW THEMES that you can try
Started by aron, April 30, 2018, 01:19:02 PM
aron
OK, you can try the new themes.
Nebula is fully responsive - so it should work on desktop through mobile devices.
SMF mobile theme is also a responsive one - but is currently somewhat broken in that you cannot change the color right now and it looks.... green.
MiniDI is another responsive theme but for some reason is all upper case.
I recommend Nebula or DIYTheme2
I switched to the black one earlier today, so far so good.
dave
I like the new softer feel to the forum index. The rounded corners the gradation.
Not related to themes....
Just seems more welcoming, more friendly.
I don't know what I have  :o
If I don't log in it looks different and the Avatars are round.
When I log in I get square ones.
KarenColumbo
Nebula looks quite fine - needs getting used to, but more air. And bigger fonts, curse my ageing eyes
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
GGBB
Nebula seems nice - but there are no like buttons.
aron
Yes, I need to mod it to add the like buttons. Will do shortly.
GGBB
Quote from: aron on May 01, 2018, 02:54:38 PM
"Like"
thermionix
Quote from: Rob Strand on May 01, 2018, 05:20:47 AM
Same here.  One little slightly annoying thing, and it might just be my OS and browser, I can no longer paste my username in to login.  See, I'm really lazy about typing, and I keep a "copy/paste" text document on my desktop with stuff like usernames, shipping address, etc.  No passwords though, always type those from memory.
Quote from: thermionix on May 02, 2018, 01:26:02 AM
It appears the default is Nebula, which is what you get when you don't log in, and we are using DIY2Theme.
FWIW,  if you can't paste with the mouse sometimes "Ctrl V" on the keyboard works.
I just tried it then and it works.   I see what is happening with the mouse, the pull-down login thingy closes when you right click.
DIYTheme2 seems fine EXCEPT the "Like" button has turned bright off-red. Really burns spots in the page. Not sure why or how it got red. If that were fixed I'd have no urge to try other themes. My experience is that many "optional themes" are only half-baked for serious forum work. (Missing features, stupid-stuff like round avatars, mouse-sticks...)
edit --- here's where the red comes from:
class="like_link"
background-color: rgb(196, 78, 25);
interesting. my browser [Vivaldi] remembers my login names, so I come here and type "d" in the "name" box, and the list of duck names appears, I click arse and away I go. just tried it in pale moon, but it didn't do it. this might be because I haven't used that browse for this site, dunno.
thermionix
Quote from: duck_arse on May 02, 2018, 10:54:26 AM
I don't store anything in the browser, and dump everything upon exit.  Persec, Opsec, Infosec, EEFIs.  FOUO, Unclas EFTO.
I will try Ctrl+V, if I can remember that (how do you get "V" out of "paste"?)
QuoteI will try Ctrl+V, if I can remember that (how do you get "V" out of "paste"?)
When it comes to computers sometimes it doesn't pay to ask why  ;D.    I see the mildy twisted logic as: Ctrl+C for copy, but Ctrl+P was already taken for printing, so you just choose V, which is next to C.  An once you start doing that it avalanches: You also have Ctrl X for cut which puts cut/copy/paste all next to each other on the keyboard.
thermionix
Ctrl+V worked for logging in.  These commands get confusing for me because I have a few different flight-sim games, and each of those has its own set of Ctrl+, Shift+, Alt+ keyboard commands.  The more common ones are programmed into the joystick.  Ctrl+V is probably a view command in some of them.
QuoteThese commands get confusing
Yeah, I'm not fond of hot keys.  They are only good for things you use everyday.   For everything else it's total pain in the butt.  The old DOS version of Microsoft word was a real pain and other words processors and editors all had their own key definitions - the bad old days really.  Some stuff could only be done with the keyboard so you had to know it.  People would have cheat sheets stuck-up on their desks.
You will find most programmers know Ctrl+X/Ctrl+C/Ctrl+V.  There's a couple of other common ones like Ctrl+Z for undo, Ctrl+Y for redo, Ctrl+S to save a document.   There will be a big list on the web for sure.  If you don't do this stuff everyday there's no need to know it.   There's a heap Windows ones as well  useful if your computer has a broken mouse.  I know Firefox has a stack of hot keys which no one uses.
marcelomd
Quote from: Rob Strand on May 02, 2018, 07:03:06 PM
IF you use an english version of MS programs. The shortcuts are regionalized as far as I know. in PT-BR the "save" command is Ctrl+B ("bold" in english versions). Ctrl+S is for "underline". Gets me everytime I have to use these programs is other people's computers.
stallik
#18
Quote from: thermionix on May 02, 2018, 05:39:13 PM
Vipectus. Latin for paste it think
dolor asinum Is also latin :)
https://en.wikipedia.org/wiki/Keyboard_shortcut#%22Sacred%22_keybindings
Some bindings originated at Xerox. Apple published User Interface Guidelines for the Mac. X-Window for unix defaults to similar keybindings. Windows copies other O/Ses imperfectly.
"The original Macintosh User Interface Guidelines defined a set of keyboard shortcuts that would remain consistent across application programs. ....The standard bindings were (with Microsoft Windows equivalents in parentheses):
    ⌘ X : Cut (resembles scissors – and the X key is next to the C key on a QWERTY keyboard; equivalent to Ctrl+X)
    ⌘ C : Copy (equivalent to Ctrl+C)
    ⌘ V : Paste (resembles an arrow pointing downward "into" the document, or a brush used for applying paste, as well as the proofreader's mark for "insert" – and the V key is next to the C key on a QWERTY keyboard; equivalent to Ctrl+V)"
Many of us learned to type on WordStar for CP/M, at a time when terminals did not have arrow-keys or F-keys. Or even two Ctrl keys. The WordStar meta commands clustered around the left hand.
https://www.editpadpro.com/manual.html#prefskeyboardwordstar
'..the "diamond" of Ctrl-S/E/D/X (s=left, e=up, d=right, x=down) moved the cursors one character or line to the left, up, right, or down. Ctrl-A/F (to the outside of the "diamond") moved the cursor a full word left/right, and Ctrl-R/C (just "past" the Ctrl keys for up and down) scrolled a full page up/down.'
