Power supply for Little Gem
Started by zener, December 14, 2003, 09:10:15 AM
zener
Just finished putting my Little Gem in a plastic box with a size if 4"x3"x1.25".  It's great. :P
I use a power supply that can switch between 3, 4.5, 6, 9 ans 12v., 750mA - 1A written in the label. When I use a 9v battery, it's so quiet while with the power supply, there's a small hiss or buzz while i turn the volume knob. Though the noise is not really audible, I want it to fix it to make it sound like that powered by a 9v battery. I'm using a small karaoke set as an auxilliary.
Thanks for any help :wink:
Oh yeah!
smoguzbenjamin
Try putting a high value cap across the + and - of the PS input.
Works for me!
zener
Actually, there's already a 1000uf cap and 1K resisitor across the power lines. I can't post the schematic but here's the arrangement of the parts:
220v - transformer - rotary switch - 4 1N4001 diode - 1K resistor and 1000uf across + & -.
Isn't the 1000uf large enough?
Oh yeah!
javacody
Zener, Peter Snowberg advised me to use a 0.1 uF cap across the rails to eliminate more noise. I did so and also opted to use a 0.01 uF cap as well (in parallel to the 0.1uF cap). This seems to have worked very well.
smoguzbenjamin
Congratulations! I'll be making a little gem if I can ever get some 386's... :P
zener
Javacody, do I have to take out the 1000uf or just add the .1uf cap across?
Oh yeah!
javacody
Leave the 1000 uF (in my Little Gem, it is a 470uF but I think bigger is better here) and place a 0.1uF in Parallel to it. You may actually want to do this on the board, to eliminate any hum picked up by the power supply cable. You would just place the 0.1uF cap going from +9 to ground.
zener
Thanks for the tip. i'll try that after few hours. It's 4:30 in the morning here. I might wake up the neighborhood  :? :shock:  :roll: .
Oh yeah!
smoguzbenjamin
Turn the volume control real quiet. Or otherwise get some sleep, you might need it if you've been up all night :)
