wicked chip
Started by Ansil, February 08, 2004, 07:54:13 AM
smoguzbenjamin
Cool, you could use that for a light-dependant wah or tremolo or something :D "Wave your foot over the pedal to make cool sounds!" :mrgreen:
Mike Burgundy
methinks light-dependant Theremin... Cool ;)
Plus the chips themselves look radical, ofcourse.
smoguzbenjamin
I've been pretending to know what a theremin is for a while now. I give up, what's a theremin? :D
ExpAnonColin
Only THE coolest instrument EVER!
This is probably the best site: http://home.att.net/~theremin1/
-Colin
Peter Snowberg
http://www.thereminworld.com/ 8)
A Theremin is an instrument that uses two antennas for input. The distance from your hands to one antenna controls pitch of and oscillator and the other antenna controls volume.
They're named after their Russian inventor, Leon Theremin. A friend of mine met him and toured with him a little in 1992/3. He was actually touring at age 96 :shock: and passed away the next year. His daughter is a MASTER of the instrument and can play it with precision. The rest of us just fumble around and make "spooky" noises.
See the schematics at the link above and build one for yourself! :D
Take care,
-Peter
Eschew paradigm obfuscation
idlefaction
555 + LDR = theremin!  :D
i made a radiowave theremin once in a stompbox, when you stomp it in the guitar signal is muted and the theremin signal takes over - it had a normal guitar jack for the antenna input, and i had it set so if you didn't have anything plugged into the antenna input it rerouted your guitar as the antenna.  it was seriously fun to play with!  moving around and closer to your amp and moving your hands around your strings...   :D :D :D :D :D
Darren
NZ
Nasse
:oops: I usually just put some vibrato, legato and pbend on my Casio CZ-1000 whistle tone. And of course some huge outboard reverb :oops:
ExpAnonColin
Quote from: idlefaction555 + LDR = theremin!  :D
Booo!!
-Colin
smoguzbenjamin
Kewl :mrgreen:
How would you do that, Darren?
Jason Stout
Scroll down to optical theremin
555
Enjoy!
Jason Stout
smoguzbenjamin
Cool! Give me a hand here on those values, check out www.geocities.com/smoguzbenjamin :D
ExpAnonColin
I'm suprised at that "Triangle type output" from the 555.
-Colin
troubledtom
Quote from: Jason StoutScroll down to optical theremin
555
Enjoy!
nice pdf link
     cool thanx,
            - tom
Jason Stout
You can try
0.01uF for the comp cap
0.1uF X2 for the freq caps (experiment!)
330 Ohms for led current limiter
I feel that you can get by without the series resistor before the cap going into the 741's noninverting input; you can make that cap 10uF, or just make it more than 0.5uF
Remove the feedback resistor, Keep the feedback path! This will give unity gain.
Make the output coupling cap big, like the input coupling cap.
Until you get it running, replace the output volume ldr and resistors with a pot, this will simplify things. Output should be taken from pot wiper (like most stompboxes).
BIAS THE OPAMP!
Have fun!  :wink:
Jason Stout
Jason Stout
QuoteI'm suprised at that "Triangle type output" from the 555
You will find that across the timing caps in 555 circuits. Using it is the harder part.
Jason Stout
mattv
Re: triangle output
Check out Small Bear's Tremulus Bear for a nice way to manipulate the triangle.
