Another completed build
Started by MarkB, April 01, 2004, 11:42:25 PM
MarkB
..and other than one amazingly stupid mistake, it came out ok.
It's hard to see in the picture, but I got a little bubbling in the clear coat.. and despite going over the artwork 100 times... I managed to label the controls backwards (rate is depth and vice versa) which i MAY change later (swap the pots/wiring)..
Otherwise, not bad... it sounds amazing.
The 'Bridge of Vibes'
http://mark.warcode.com/diy/bridge.jpg
bwanasonic
Whoah Dude! Sweet finishing! T-Shirt Transfer? I gotta get me some of that.
Either that or send all my boxes to you for finishing! :idea: :wink:
Kerry M
DaveTV
DaveTV
Sings:
Why so unforgiving?
And oh why so cooooold?
S'been a long time building...
Bridge of Vibes.
Peter Snowberg
Sweeeeeeet! 8)
I'm really glad I said "let's take this exit, it's a great overlook of the bridge". :D
Thanks again for the ride! 8)
continues singing...
Cold wind blows
The Gods look down in anger
on this poor wiring
Why so unforgiving
and why so cold
Been a long time building Bridge of Sighs
Take care,
-Peter
Eschew paradigm obfuscation
MarkB
yeah, Peter.. that's the shot..
that picture of the bridge is a photoshopped copy of a picture that I took when he was giving me the local tour of San Fran...
I had originally used a stock photo in there.. then I got home and realized that my shot was better.
Hard to tell when it's all purple and green, but still...
PS.. I can't believe that nobody used the name 'bridge of vibes' before.. it seems like such a natural...
uncle boko
Funnily enough, I walked under the said bridge in Oxford, England 2 hours ago!
better to be in bad taste than to taste bad
DaveTV
And funnily enough, I'm rowing underneath the Bridge of Sighs in Venice in a gondola as I write this...okay, that's not exactly true.
From what I understand, the bridge got its name because supposedly it was the last view of Venice that criminals saw as they were being led to prison....SIGH!!!
I've never seen it in person, but I have passed under the one in Oxford as well. That one doesn't require a gondola (at least I don't remember if it does--we were coming back from the Turf Tavern after a few pints).
RDV
Looks great! What circuit is that?
I played "Bridge of Sighs" tonight, really loud, with me little ho-made Phase45 doing the whooshing!
Long Live Rock!
RDV
modmod
nightingale
markB~
exactly which brand of Tshirt transfer are you using? i have not had the best luck with the stuff i found at my local hobby shop.
that one is definately a keeper,
be well,
ryanS
www.moccasinmusic.com
MarkB
Modmod - it's an EasyVibe.. John Hollis' design.. made to mimic the sound of the Univibe.. and does a pretty darn good job.
As for the T-shirt stuff... I'm using Avery #3279
RDV
Quote from: MarkBModmod - it's an EasyVibe.. John Hollis' design.. made to mimic the sound of the Univibe.. and does a pretty darn good job."-)
That's what I thought it was. I dying to build one of those! Did you make your own PCB from R.G.'s PDF? Also, do you put shrink wrap around the LDR/LED combos?
Thanks in advance!
RDV
MarkB
Yup - went right off RG's layout..  used TL062's like the schematic calls for... used the little LED/LDRs that Steve sells and 'rolled' my own with shrink tubing.
It sounds GREAT.. very very happy with it.. coolest build for me so far.
RDV
Sorry for the bump, but has anyone used TL072 instead of 62 in the Easyvibe with good results? I'm just wondering do I need to order more parts.
Regards
RDV
Arno van der Heijden
QuoteSorry for the bump, but has anyone used TL072 instead of 62 in the Easyvibe with good results?
Yes, I did.
troubledtom
RDV
How about TL2262?
Regards
RDV
MarkB
RDV -
Apparently it DOES work, but it can cause problems..
Socket them, order some 062's, slap in some 072's while you're waiting and see if they work.
