MAX1044 equivalent with higher Vin?
Started by saxtim, April 07, 2004, 03:35:40 AM
saxtim
Does anyone know if there is an equivalent charge pump of this kind that will accept a higher Vin max?  I'm looking to feed it 12 or 15 volts.
Another question, can you use the voltage doubler/tripler described at RG's site with a negative supply?  Does this require an different IC or will these charge pumps accept positive and negative voltages?
thanks
tim
Nick123
TC962  could  be  an  answer.
Vin  is  from  3  to  18V  and  Iout  is  80mA.
saxtim
Hmm - that looks positive, however looking at the data sheet I wonder about the oscilation frequency.  It says you can ground one of the pins and that doubes the frequency to 24Khz - I'm wondering if that's still too low and will interfer with audio?
Also is there a chip that will do a negative voltage multiplier?
I'm trying to get a +/-60V supply give or take.  I've found a chip that will take a positive input voltage and output +/- 12 or +/-15 volts.  So taking care of the +60V seems not so hard.  It's the - 60V I don't know how to get at this stage.
thanks
tim
saxtim
I waded through some more data sheets and I found this:
http://www.maxim-ic.com/quick_view2.cfm?qv_pk=3138
this looks like it might be better- will output up to 36V and then you can use a capacitor charge pump to bump that up.  Will be much easier to get it up to 60V (should only take one stage of diodes/caps).
