i need some help with my transistor....
Started by el duderino, April 26, 2004, 08:53:02 AM
el duderino
Hey i started to build my first distortion unit and i need help with the transistor, its a general purpose NPN its black and the three pins are coming out of it in a straight line.
i can read the normal silver ones with the little tab where the emiter is but i cant read the small black ones can someone help!?
please. :?
you can keep my finger nails clean
Ge_Whiz
We need to know the transistor number - the pin-out order varies between different types.
Peter Snowberg
Welcome to the forums. :D
Just for future reference, the case style of your transistor is called TO-92 and for most general purpose NPNs if you have the flat side facing you with the leads going down, the connections are usually E-B-C. As Ge_Whiz points out though, you really need the number to make sure. There is a lot of variation out there.
Take care and best of luck on your build!
-Peter
Eschew paradigm obfuscation
I just put them in the DMM's Hfe checker different ways till it shows some 'reasonable' Hfe #, then try it in a circuit that calls for something like it.
 I didn't know how reliable this is, but it seems to work every time for me.
