ground question......
Started by el duderino, May 05, 2004, 08:26:22 AM
el duderino
Hey i was just wondering when you are making a project which dosnt
require a battery and you have to ground it is it ok to solder the ground wire to the back of the pot?  :?
if im wrong is there any other ways to do this???? :shock:
thanks
eamonn
you can keep my finger nails clean
lightningfingers
"black ice" distortion and its subsequent imitators do pretty much what you want.
search through the archives, there is a mass of posts on it.
U N D E F I N E D
Samuel
This is done in many guitars. Its fine, as long as that goes on to connect to every other point that needs grounding...
