BSIAB II error
Started by Ed G., June 28, 2004, 03:20:31 PM
Ed G.
After building a BSIAB II using Jake's layout, I found an error on the value of a critical component:
C10, which is a cap on the LPF of the BMP tone stack, should be .02, not .002. This should fatten up the sound and make the tone control sound like it's actually doing something.
I've already emailed JD Sleep so he can correct it.
My apologies to all,
Ed Guidry
Lonestarjohnny
Just changed mine and tried it again, totally had to re EQ the amp, made a big Diff in the way I had the amp adjusted, Still sounded good the way I had it though, now its easier to EQ.,
Thanks,
JD
Ed G.
Yeah, I like to voice the pedal so that you can have a nice bright rhythm tone, and then step on the pedal and you have that 'brown' sound, not really harsh and spiky but with a good blend of harmonics.
