Does 12volts fed tubes glow!?
Started by Kaiowas, July 14, 2004, 04:33:37 AM
Kaiowas
As short as that...
Does 12volts fed tubes glow!? Do they show that beatiful "orange-glow"?
ah!...How do i tweak the sound (tone) of the Ruby Boost? Wich caps or resistence do i have to play with?
"De quién era la piragua?!"
Kaiowas
jimmy
its the heaters that glow, unless youve done something wrong... so i spose yes they will.
are we talking about the sopht amp site ruby or the ROG ruby?
cheers
Jim
"Who the f*** are the naked chefs?" - Ozzy Osbourne
tubes or bust
aron
Yes, if you are wiring them to use 12V, yes, the heaters will glow.
I used a 9v 800ma WW power supply and connected that to the heater lugs [4&5] of a 12AX7, and under the load the circuit measures 11.2v...close enough I think, you want the measured voltage of the circuit to be close to the tube rating for optimal performance and longest heater life....sezz the RCA Tube Manual.
