Small Bear on vacation and I need 100K 16mm pots
Started by nirvanas silence, July 19, 2004, 11:15:58 PM
mikeb
It's too hard to order from Australia? We Aussies have to order from overseas all the time, perhaps we are more accustomed to doing so.
If you really need help, please let me know. I can pick up the pots during my lunch break and post them to you ASAP - airmail takes 7-10 days to the USA usually. (Note - these are for D-shafts; no place in Australia even carries the round shafts AFAIK).
Cheers
Mike
Brian Marshall
unfortunately mike, for the pedal i use them in the pots mount sideways, so i dont think the D would work
mikeb
That's cool - I was thinking you can bend the pins back 90 degrees and save some space, but maybe that won't work either.
Cheers
Mike
Brian Marshall
actually not that i think about it that is the only pot in the pedal that IS facing the right way.
Where does the flat part of the shaft face when the pot is centered?
sorry if i was an A-hole earlier mike.
