Will "Thor" (runoffgrove) run on 9V batteries?
Started by pd3, June 11, 2010, 12:24:07 PM
pd3
Hey there.  I'm pretty much ready to pull the trigger on the Thor pedal.  What I hadn't considered is whether a 9V battery (or two in parrallel) will provide enough current to ru n this pedal.  Where its main gain components are 4 Fets,  I'm thinking (or hoping!) that this pedal will power up on battery power.   I'd be happy to hear from you about this "little oversight!".
Thank for your time!
Phil
Scruffie
Yeah should be fine for a while... not sure how long it'll last on battery but it will work.
MikeH
Why wouldn't it run off a 9v battery?  I don't think it's current requirements are any different than any other pedal.  It has far fewer components in it than your average Boss or Ibanez distortion.
pd3
Thank for the replies.  I had a feeling it would be fine, just got a little concerned when realizing I hadn't thought about it.  Well, then that little horizontal battery compartment should be fine in the "BB" enclosure. Now, time to find a nice way to make the rectagular opening for it.  I was thinking using the wafer cutting wheels with the Dremel.
Thanks,
Phil
GeorgeSunset
build on ones.
it works fine with a 9 V battery. i think it gets more headroom and becomes just a bit "MORE" on 12 Volt. never tried it with more voltage though.
stringsthings
anyone care to post a soundclip ?
inquiring minds would like to hear !  :icon_mrgreen: ..... here ! here !
