Schematic Questions
Started by Mackguitar92, March 14, 2012, 02:45:20 PM
Mackguitar92
Hey guys, quick question on this schematic.
http://www.smallbearelec.com/Projects/ReverbPedalSchematic.pdf
What does the "SW" and "REF" mean that are coming of some of the connections/components?
Mack
CynicalMan
REF is the reference voltage for biasing the op amps. It's made by the 1M/1M voltage divider on the bottom left and buffered by an op amp.
SW connects the bypass switch to the CMOS LED driver stage on the bottom right.
Just wire all of the pins marked REF together, and wire all the pins marked SW together.
Mackguitar92
Thanks Alex.  This really clears things up.
charmonder
In that diagram, is the CMOS part just there to turn the led on and off? Is this a type of millennium bypass?
successful transactions with forum members: bcalla, digi2t, and gutsofgold
Yeah it's a variation of the mil bypass.
CynicalMan
It's close to the Millenium C, but not identical:
When the effect is on, the leakage of the 1N914 diode pulls up the voltage on the inverter input, making a low output. Because the LED is connected to 5V on the other side, this makes it light up. When the effect is bypassed, the switch connects the input of the inverter to the 100k resistor. This makes the input low, so the inverter has a high output, making the voltage over the LED close to zero.
