Neo Vibe Troubleshooting
Started by parser, March 07, 2022, 10:24:16 AM
parser
Hello,
I powered up my implementation for a NeoVibe at http://www.geofex.com/Article_Folders/univibe/vibeupdate.pdf  and surprisingly, at first attempt, I had the lamp pulsing and working properly. The problem is in the sound that appears to be UNPROCESSED at all.. do you have any advice where I should put my attention on ?     :icon_neutral:
Kevin Mitchell
Hey, welcome to the forum.
With the info provided it sounds like an issue with your bypass switch wiring. But we can't confirm that since more detailed photos have not been provided.
My apartment looks like an imploded RadioShack.
parser
Hi Kevin, thanks for helping me. I'm not using a DPDT by now (since I'm testing the unit) so, the effect is always in the "EFFECT ON" path. The ground was not properly connected to the L pad. Now it is, but the effect still doesn't process the signal. Moreover, if I set the volume at top, I just hear noise. I added another picture...
antonis
Hi & Welcome..  :icon_wink:
Have you performed testing with photocell covered..??
Kevin Mitchell
Oh, okay. Smart move! And thanks for the full picture.
If you have no guitar signal at all on the output then you likely have a short, cold solder, bad trace or bad part somewhere along the signal path (more likely a short). You should make an audio probe, follow the schematic and see where the signal drops out.
In case you didn't know, without the cap on the LDR/Lamp setup your room's light will keep the LDRs stuck on low resistance so you won't really hear the phasing. But that wouldn't cause the guitar signal to disappear.
Do you hear any artifacts from the LFO pulsing? If not then perhaps the error is further down the circuit near the output stage.
Good luck!
parser
 :D
.. and actually it was a short after soldering! I have now a deep phasing effect. BTW, yesterday I fried a transistor (Q12) trying to read voltages..
Thanks a lot again  ;)
Kevin Mitchell
Awesome, great job!
Onto the next!
parser
Quote from: Kevin Mitchell on March 08, 2022, 08:06:42 AM
Onto the next!
Yep, it will be a Distortion Device whose project is taken from a 1978 magazine. It has 6 BC109C NPN transistors, 3 knobs and 5 switches.  ;)
antonis
Kevin Mitchell
Quote from: antonis on March 08, 2022, 08:34:48 AM
Awesome, great job!
Onto the next!
2 fried transistors, at least..?? :icon_lol:
Sometimes you've got to blow up a few parts to learn and move forward!
When a new member comes along and more-or-less troubleshoots their build themselves, it's indeed a great job. Especially on a home-etched board like this one.
parser
Quote from: Kevin Mitchell on March 08, 2022, 09:06:25 AM
Awesome, great job!
Onto the next!
;D BTW, my board was an "artwork" all etched by myself with a dremel tool (yes man, it can be done )  :icon_lol:
parser
[/quote]
Exactly one (Q12), to be precise ;)
Kevin Mitchell
My goodness, man! Well... that's one way to do it.
I've never wished to unsee something as much as this. Ok I'm over exaggerating, but it works and that's quite impressive! So box it and never show it again :icon_lol:
Hit the bottom of the board with some clearcoat to prevent oxidation.
And please try an chemical etching next time lol. You'll save yourself a ton of work.
