Need:change AC to DC diagram
Started by 549, January 04, 2004, 08:49:07 AM
I will set 2 tranformers inside effect box.
but tranformers are AC , I must change to DC
anyone  have diagram circuit??? :?
or link site
thank you :wink:
Mike Burgundy
If you don't know what you're doing don't mess with AC. it's deadly if not done properly (think about waht would happen if your strings were hooked up to a wall socket). Transformers need to be well isolated electrically (safety), and need to be positioned in such a way that they don't interfere with each other and any other circuit nearby (they have a rather powerful magnetic field that hums at 50-60Hz, and you *will* hear this through audio circuits). A good fuse at a correct value and other protection arrangements are due here. Oh, and they can get hot.
That said, what you need is a rectifier and filter section maybe even with a regulator. The exact circuit used depends largly on transformers used, required voltage, current drawn, filtering requirements, the circuit you're feeding, etc.
549
Hmm.....thank you
It's a new knowleage to me. :lol:
smoguzbenjamin
After almost killing myself when I shorted a PSU once, my advice would be not to mess with AC unless you're an experienced builder. Buy a wallwart with different voltage outputs, that'll supply all your DC needs.
