Easy multi face question
Started by jimbob, January 08, 2004, 02:38:43 PM
jimbob
When switched on i get no sound--when switched off i get sound. I think iver chked over everything a million times incl values and connection ect.. Question= If i put the led in wrong could that keep circut from performing at all?  And, does it matter the size of the led? I used a 5mm. Also connecting this to a dpdt switch = would this be a good plan to go with? http://www.muzique.com/schem/dpdt2.gif
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
b_rogers
for debugging i would leave the switch out, and probably the led too..i had the 22uf cap backwards on mine that took some staring at to figure out...dont give up. do you have dmm? maybe post the voltage at c,b,e of both q1 and q2 would help some of the smarter folks around here figure out why yours doesnt work.
Brent
homegrown, family raised couch potatoes. temperament unsurpassed.
http://electricladystaffs.com/
