Which Enclosure ?
Started by timrand, January 18, 2004, 07:51:27 PM
timrand
Hey Guys have a look at this link.
Which Enclosure would you recommend for a Fuzz Face type of Project ?
http://www1.jaycar.com.au/productResults.asp?FORM=CAT
This is a pretty good electronics store and all in Australian $$ cheap for the US
Peter Snowberg
Sorry, but the link doesn't work.
Part numbers?
Because the fuzz face is so small, your only real question (after is the box metal?) is if you have the space to mount two pots, two jacks, a stompswitch, and a battery in there along with the FF circuit. Of course you also want something stompable. ;)
Take care,
-Peter
Eschew paradigm obfuscation
timrand
www.jaycar.com.au
Other than that where would everybody recommend for cheap parts to build this item ?
bobbletrox
http://www1.jaycar.com.au/products_uploaded/productLarge_828.jpg
I've used their 119 x 93.5 x 34mm Economy Die-Cast Aluminum box (the top of the pile of 3 in that pic).
Get yer transistors from www.smallbearelec.com -but then you might as well buy a Taiwanese "B" enclosure while you're at it!
Peter B
G'day Tim,
I use the Jaycar HB5067 encloure for my effects (119x93x34mm).  It's pretty close to the Hammond box the guys in the States use.
For a FF you could get by with a smaller enclosure maybe, leave that to you.
Hope this helps,
Peter
timrand
