386 as a voltage divider - From GEO
Started by Phorhas, March 11, 2004, 03:31:19 AM
Phorhas
I ran across this article in R.G's page cocerning the design of referance voltage networks http://www.geofex.com/circuits/Biasnet.htm
Considering that last part - when using the 386 chip as a voltage divider, does the Vr needs to be filtered (large cap rom output lug to groung lug)?
Electron Pusher
smoguzbenjamin
Quote from: GeofexWith no input signal, its output sits at half the power supply and sources/sinks current to keep the output nice and quiet at that voltage. You don't even need biasing resistors or caps, since its inputs are self-biased at ground.
Nope ;)
Phorhas
Electron Pusher
