Help w/ Tube Driver
Started by Jason D, March 14, 2004, 03:01:18 AM
Paul Marossy
Oh yeah. I forgot about the choke part.  :oops:
And it is very true that the layout is important. Sometimes a signal path will pick up a hum from another part of the circuit. I always tightly twist my heating filament leads and keep them close to the chassis and as far away from everything else as I can get.
Jason D
well, so far I tried everything....so now I am going to copy the original PCB trace for trace part for part.
I've looked at it so many times now, this should only take a minute.
I believe I will even wire the bypass  switching up the same way.
Paul Marossy
Reminds me of my first Shaka Tube build.  :(
Hope you get it working the way you want it to the next time around. You might want to ask the forumites here if they have built this one. I seem to remember reading that the Tube Driver thing at GGG had some problems...
Jason D
I believe the problem is in the layout, mine or the GGG one.
So I am in the process of copying the real thing.
Let you know how is goes.
Jason D
The results are in ----- the problem was my layout!
I now I have an exact copy of an original Tube Driver. Actually I didn't have another 2200uF, which is what the original used, along with a pair of 220uF and a 470uF. I used a 1000uF and three 470uF caps. It didn't seem to mind.
Anyway, right now I am very happy (and tired).   :lol:
puretube
congrats! glad to hear...
