Germanium or Silicon?
Started by crawler486, May 05, 2004, 05:57:51 AM
crawler486
Can you distinguish a Germanium from a Silicon
by just looking at it?
Ge_Whiz
Sometimes. It depends on your expertise. A very old germanium metal-can transistor looks very different from a modern plastic one, but there was a changeover period when the packaging was much the same. Some folks also have an encyclopaedic knowledge of the part numbers.
Generally, to the lay person, I would say 'no, you can't'.
crawler486
I scavenged some diodes that is clear and has black stripe,
can it be a germanium?
brrt
Could be. I can't think of a silicon diode in a clear package.
Brrt.
acromarty
A better way to distinguish is to measure the forward volt drop. A silicon diode drops about 0.7V, whereas a germanium diode drops about 0.3V.
You can't tell from the package unless you can decode the stripes into a number, like with resistor colour codes. Silicon diodes such as 1N914 or 1N4148 have a clear glass package with stripes.
Cheers,
Andy
