Does Anyone have a PHASE90 Perf-Layout ??? PLEASE!!!
Started by Kleber AG, June 17, 2004, 05:51:35 PM
Kleber AG
I'd really apreciate!!!  8)    8)   8)
If so, can you email me: kagaxdx@yahoo.com
Kleber AG
lightningfingers
just take Tonepads, GGG or someonr elses PCB layout and build it on perf using the component leads where the copper traces would normally be. It may even fire up 1st time.
good luck :mrgreen:
U N D E F I N E D
I perfed a 90.
I came out a little crosseyed, not bad for a phazer, would order pcb if I had a choice.
 I chose to follow the schematic though, not too tuff, 5-8 hole spaces around the each OA is highly recommended, otherwise it gets too Dantight..
 A little bit of DMM probe lead access on component leads above the board is nice...leave enough lead above board so you can touch right there, leave an angle for the probe to approach.
 Schematics are laid out pretty straightforeward as far as input to output / left to right, except opamps wirings.
 If box size isn't a 'big' issue, start with a little extra 'acre' age on the perf size...then I chip away the extra perf with wire cutters....after.
