OT: tube radio
Started by lightningfingers, July 08, 2004, 01:31:16 PM
lightningfingers
Hi all!
I wanna build a tube radio for my dad, and umm....i don't know where to start. I have some limited(?) experience w/ tubes (i have built a real mctube II, and an AX84 P1). Can anyone point out a good cite for noobs?
TIA  :)
U N D E F I N E D
Lonestarjohnny
Antique Radio site, there you'll find a lot of info, and if you can read everything there, your sure to be gray headed by the time you finish.  :lol:
JD
Markusk
Hi, try  www.jogis-roehrenbude.de
tons of radiomakerthings :idea:  :idea:  :idea:  :idea:  :D
John 3:16
For God so loved the world, that he gave his only begotten Son, that whosoever believeth on him should not perish, but have eternal life.
Ge_Whiz
//www.peeblesoriginals.com
Mike Peebles is a great guy and will provide loads of help and support. Tell him Ge_Whiz sent you.
lightningfingers
U N D E F I N E D
lightningfingers
Hmmm.....
If I built a crystal reciever, then stuck a hifi valve amp on the end of it, would that work?
U N D E F I N E D
Paul Perry (Frostwave)
Quote from: lightningfingersHmmm.....
It will work, but not as well as if you did it in 1930. Because then, there was relatively little noise from electrical machinery etc and few radio stations nearby to the one you wnated to tune in to. Today you get a huge mess of noise & a pile of stations all at the same time, if you live in the city.
But by all means build a RF set! you will learn lots!!
Ge_Whiz
You'll need a good antenna and earth for a crystal set. The Xtal Set Society (XSS) at //www.midnightscience.com does a one-tube regenerative radio set, which will still need an amp, but this could be an IC design. Mike Peebles designed these sets, so will give good advice and can help with parts.
lightningfingers
Those sites are helpful, but all those schematics use really OLD tubes. Isn't there a radio that uses a commonly availible tubes, like a 12AX7 or something.....?
U N D E F I N E D
Ge_Whiz
Well, the 12AX7 is an audio valve, not intended for RF work. You'll find the 1T4 much easier (and safer) to use, and at about $4...
lightningfingers
U N D E F I N E D
Ge_Whiz
Sorry, my mistake - $2.95. From the XSS, like I told ya. Ignore the out-of-date websites - e-mail them.
