left-over 2n3906's
Started by cajununicorn, January 26, 2004, 12:06:24 AM
cajununicorn
hey folks,
i have a lot of 2n3906 trans left over from a project and i want to do something with 'em... does anybody have any ideas on a project i can build using these?   thanks, jon
ErikMiller
Simple boosts? There are so many things you can do with those.
I always figure if nothing else, no matter what the transistor, I can make a single-transistor booster.
Ansil
well what do you want to do a gain thing a eq a phaser what.. you could do most anythign you want with it.   a little practive amp
cajununicorn
thanks for the quick replies....  i'm kind of a newbie, so probably NOT an ada flanger or sansamp! maybe a boost or drive...
i just haven't found many pnp projects on the usual sites. ideas or schematics greatly appreciated!    jon
jimbob
Id be interested in an eq thing. Ideas?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
brian wenz
Hello Hullo--
   Hey Jon, how about some kind of single-tranny booster?  [LPB-1,  Gus'  NPN Boost,  etc....]  Check around  in the "Schematics" section.  {Actually,  Aron did a step-by-step tutor session on the NPN Boost at the top of this forum.]   One good thing about these is that they are "Fender amp friendly".  Some  of the Fuzz Face type stuff doesn't play well with Fenders!    [Having said that,  maybe you could throw together Jack Orman's  "Yaff" Fuzz using two 2N3906's.........low gain trannys sound REAL GOOD in Fuzz Face circuits!]
Brian.
Convert any NPN transistor ckt I know of to PNP...just change the battery, and polarized capacitros, and diodes [invert the polarity] check out the reads around here for more ingo
cajununicorn
thanks for the info...i didn't realize it was so easy to covert npn/pnp designs. i'd like to try a rangemaster style build.
casey
joe gagan has alot of 2n3906 based circuits.
Casey Campbell
brian wenz
Hello Hello Jon--
  The Rangemaster / Treble booster circuit is not really  "Fender Friendly" [At least not with the amp set-up you've got].   Try a more "full range" booster like a LPB-1 or NPN Boost.  Also, the transistors you've got [2N3096] lend themselves more to a full range booster.  Save the Rangemaster-style build for a good germanium [or, a well thought out and correctly biased silicon] tranny!
Brian.
cajununicorn
thanks brian. i'm going to try the npn boost (pnp boost!) with the extra eq circuit at the end. by the way, do you have a local source for germanium transistors?    jon
brian wenz
Hello Hello Jon--
   Email me.
Brian.
