tl062 sub ??
Started by igor12, August 15, 2009, 01:16:07 PM
igor12
Can someone recommend a sub for the tl062 ? Low current but better noise specs? and not too expensive. I don't really care if it is a fet device.  There has to be something these days!
ballooneater
The NE5532 would probably work.  It may be a bit more expensive, but not much.
Gus
There are other FET input opamps.  The thing is if you are cloning a circuit that uses a 62 you might need a 62 because of how it was designed.
A 5332 might not work right if the input resistance of the opamp need to be in a Jfet range
