Author Topic: Harmonic Fusion Engine  (Read 5308 times)
~arph
« on: November 27, 2012, 04:48:37 AM »
Thought I'd give it a thread here too..
Here's something I threw together. It's called the Harmonic Fusion Engine and it's a marriage between two great effects with Harmonic in their name.. The Systech Harmonic Energizer and the Harmonic Jerkulator (By out pal Tim Escobedo). It also incorporates Jack Ormans SWTC. What I did was removing the gain stage from the energizer and use the free opamp as an input buffer. Also I Fixed the bandwith pot at max. Finally I blended in some of the clean signal into the jerkulator to keep some bottom end when the frequency is set high.  I used 2N209 and 2N3404's for the jerkulator. The schematic misses two 220pF caps from B-to-C on both transistors for noise reduction. They are on the vero.
Schematic:  https://dl.dropbox.com/u/1849818/hfe-fixed.png (ignore the comment on the range pot.. it's fine)
Vero:          https://dl.dropbox.com/u/1849818/hfe-verified.png VERFIED  ;D
Soundclip:   http://soundcloud.com/arrfx/harmonic-fusion-engine
Tight fit:
If you lower the footswitch you can even squeeze in a battery.
BUILD IT!
« Last Edit: November 27, 2012, 04:51:35 AM by ~arph »
pinkjimiphoton
Re: Harmonic Fusion Engine
« Reply #1 on: November 28, 2012, 02:01:52 PM »
bump!!
listen loud. blaze one first:
https://drive.google.com/open?id=0BzMJxNNgY3_yc0JNd0VqdmNIWEk
I stand for Truth, Justice, and the American Way. @#$% TRUMP! YOU ARE EITHER ANTI FASCIST, OR YOU ARE ONE. #BLM
#FuzzyGoodness
John Lyons
« Reply #2 on: November 28, 2012, 02:34:38 PM »
I likey.
Basic Audio Pedals
www.basicaudio.net/
~arph
« Reply #3 on: November 28, 2012, 04:28:31 PM »
You can sell them John if you make me one  : : ;D ::)
cliffmustard
« Reply #4 on: June 30, 2013, 01:44:30 PM »
Just wanted to say thanks for designing and sharing this one. I got it together today and absolutely love it!! Some really great fuzz wah type sounds in there. I used 2n5089 for the NPN, 1n270 diodes and removed the 22k to the volume (in the hope of giving it a bit more volume). Cheers!
~arph
« Reply #5 on: June 30, 2013, 06:27:58 PM »
Remove the diodes for volume.. Watch out though it's LOUD
pinkjimiphoton
« Reply #6 on: July 31, 2017, 12:04:48 PM »
hey ~Arph, the links have gone down. any chance you could please repost them? i've been planning on doing this for like years now and can't find the files i thought i'd downloaded!
thanks bro
#FuzzyGoodness
~arph
« Last Edit: August 01, 2017, 03:41:18 AM by ~arph »
pinkjimiphoton
« Reply #8 on: August 01, 2017, 12:05:12 PM »
awesome, thanks arnoud!!
hope to have one built up over the next few days ;)
#FuzzyGoodness
~arph
« Reply #9 on: August 02, 2017, 05:28:17 AM »
Cool, I hope you like it. You can always tweak the jerkulator side to taste.
