Author Topic: Humbucker or Single Coil Pickups in my Encore hollow body - Pics Included  (Read 3006 times)
The_Bloody_Omen
Hay can you guys tell whether or not this are humbuckers or single coil pick ups?
http://imgur.com/a/Pwoie
Also does anyone know what wiring it would be?
Again also I build a BYOC leeds fuzz. What material would people recommend to put decals on? Waterslide?
Thank you so much,
The_Bloody_Omen
G. Hoffman
Thank you so much,
The_Bloody_Omen
I don't know why this is in the Digital area, but those are single coil pickups.
Gabriel
The_Bloody_Omen
Thanks dude, sorry for the misconception.
The_Bloody_Omen
Do you know how the wiring would go for that bad boy?
JohnBlakeArnold
Hi,
yes old school single coils.  Since you have the guitar taken apart, and need to rewire anyway, you might consider an on-board buffer/boost similar to the Jack Orman MOSFET booster immediately after the pickups, which would allow great impedance selection, and a lot of configurability with push pull pots, so no new holes would have to be drilled.
I do have schematics for a personal build.  I designed it for personal use in almost a same case within a hollow body.  Further, having the buffer inside could help with a viable control versus feedback.
Anyway, you should move the post elsewhere, unless you assumed the pick ups are digital, which they are not, they are analog.  Do some good reading on Wikipedia to explain pickups!
Hope this helps at least a little. Nice green finish on the guitar. :icon_mrgreen:
The_Bloody_Omen
To JohnBlakeArnold,
   Hay thank you for your time; However I do not know the appropriate place for this discussion. Also I have no idea what you are talking about lol. I do not know why you would need a transistor built right in the shell of the guitar. Also I found this:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2phatcats_2vol_2t_3way2
I think this will do the trick, however would not cover the second switch. (There are two 'SPDT' switches on the guitar).  Also can I buy the braided cable at like Stew-Mac.com or just use two wires instead?
Thank you so much,
The_Bloody_O
