Show us your SMD stuff.
Started by alparent, March 05, 2013, 02:39:02 PM
DirkM
#100
Diy modern DSP project in a 1590A enclosure  ;)
Ice-9
Two tier PCB's main board and plugin top control PCB
www.stanleyfx.co.uk
Nice one, Mick.  Very cute.  :icon_cool:  What is it?
Ice-9
Quote from: bluebunny on August 15, 2018, 08:44:01 AM
Cheers Mark, it is the Baby Blue Echo, Meazzi and Vox long tom tape echo emulations.
www.stanleyfx.co.uk
italianguy63
#104
Quote from: Ice-9 on August 15, 2018, 08:58:45 AM
That's awesome work!
Is R35 missing on purpose?  (Just noticed C29 also)
Ice-9
Quote from: italianguy63 on August 15, 2018, 09:26:43 AM
Yeah both not fitted, R35 was not used in the circuit and C29 is part of the bypass LED for help with bypass pop but not needed anyway and I had none left for now.
www.stanleyfx.co.uk
italianguy63
Just wanted to be sure!  After you box it up and it doesn't work you want to die!!
MC
MJ_Sound_Cubed
Do you guys make arduino based pedals as well? Or only PIC?
♫♪.ılılıll|̲̅̅●̲̅̅|̲̅̅=̲̅̅|̲̅̅●̲̅̅|llılılı.♫♪
MJ Sound Cubed
Community driven website to share your work at soundcubed.com
Ice-9
www.stanleyfx.co.uk
MJ_Sound_Cubed
Are these circuits shared somewhere? Or the PCBs purchasable somewhere?  ;)
MJ Sound Cubed
Quote from: Ice-9 on September 07, 2018, 04:11:16 PM
Quote from: MJ_Sound_Cubed on September 07, 2018, 03:52:57 PM
Both
And then some. The last two posted were an Arm chip and an FV-1, not either PIC or AVR.
I decided it's been way too long since somebody posted in this thread, so here's what I've been working on recently:
Bipolar power supply: I decided I was tired of playing with Tubescreamer variants so I'm going to play with a Providence Stampede SOV-2 and see where that takes me. I liked their idea of bipolar ±15V rails, but I didn't like how they got it (9V in -> 7805 down to 5V -> expensive module for bipolar outputs) so I designed my own supply that goes straight from 9V to ±15V with a cheap yet efficient switcher. I spaced the pins so it can drop straight onto the breadboard and I will be playing with it eventually when I have some time ::)
Tidepool: It's a Shoot the Moon tremolo. That's it. The original version that's out on the internet fit in a 1590B just fine with through-hole components, but 1) I wanted board-mounted pots and 2) SMD is neat.
BrontoChorus: EHX Small Clone with board-mounted pots and form-factored for a 1590B. I have a bunch of V3207, but I forgot to swap to positive rails so it has to take MN3007 :P
Black Mirror: I'm more proud if this than I am of pretty much anything so far, even though it's still in the testing stage. This is a Deluxe Memory man with board mounted pots and form-factored for a 1590B. Think that's pretty cool? Check this out: It takes a standard +9V input but runs internally at -15V, but keeping a neutral ground so it can still play nice daisy-chained. Again I used a neat little switcher to go from +9V to -15V internally. Unfortunately the modern production V3205 (which I have loads of) only runs up to 11V max, so this also will require MN3005s. Oops. Also I didn't follow the routing guidelines for my switcher so it's not giving me the current output it's supposed to, so I'm dealing with that (which is why the upper-right corner is torn up). Anyway, seriously super proud of myself ;D
alanp
Quote from: vigilante397 on December 27, 2018, 01:12:03 AM
You should be proud of all of that!
mookyj
One prototype I can show as all my customers I have are under NDA. for reference this board will fit in the palm of your hand.
welcome, mookyj - can you explain something I've often wondered at? those interlocking fingers tracks, and the ones that go back and forth in a long line - what do they do, printed inductors? timing delays? something else?
mookyj
those would be matched nets such as LVDS pairs, differential pairs, data busses, etc. sometimes called accordions.
Quote from: duck_arse on December 28, 2018, 08:26:34 AM
those interlocking fingers tracks, and the ones that go back and forth in a long line - what do they do?
High-speed signals like the ones mookyj listed (often referred to as differential pairs) need to be length-matched for signal integrity, and accordion-ing is the typical way to tune the lengths of the traces.
So mookyj, are you going to tell us what it does? :D You don't often see a single board, especially a small one, with three FPGA's on it! :icon_eek:
mookyj
handles very high speed video from image sensor, processing, 80K frames a second, 138db Dynamic range , single electron noise reads
gena_p1
Quote from: Ice-9 on August 15, 2018, 08:09:24 AM
looking good, interesting why do you use 3x multiturn trims and one usual?
gena_p1
Little evolution of Twin/Olympic preamps
