The easiest way to wire a DC power jack in is to cut off the battery connector and solder the black wire onto the "to input jack ring" contact and the red wire onto the "+9v to circuit board" contact.
http://www.diystompboxes.com/smfforum/index.php?topic=970.0
Quote from: thelonious on March 14, 2013, 12:14:39 PMThe easiest way to wire a DC power jack in is to cut off the battery connector and solder the black wire onto the "to input jack ring" contact and the red wire onto the "+9v to circuit board" contact. Great. So basically I can wire any pedal with a dc jack by replacing the pos and neg battery terminals with the pos and neg on the dc jack?
I can't think of a situation where that wouldn't work, unless something really unusual were going on with the wiring. The center pin of the DC jack will be negative. Also, don't try to do this with PNP devices like positive ground fuzz faces unless your power supply has outputs that are isolated from each other.
