Author Topic: Circuit trouble  (Read 4750 times)
VolksWilliam
Circuit trouble
« on: March 23, 2013, 10:47:53 PM »
Ok. Just finished the npn boost. Here's the problem. I've got true bypass signal. When on I've got led but only very low volume.
I don't have a way to take a photo right now but I took some measurements and maybe someone can suggest a fix for me.
All volts are as should be besides the transistor.
E 2.74
B 2.89
C 3.54
Triple checked the schematic but I've already had to fix a few things. So where do I start now?
petey twofinger
Re: Circuit trouble
« Reply #1 on: March 28, 2013, 12:47:47 PM »
double check soldering , prehaps reheating each joint . make sure there are no solder bridges . are yuou sure the transistor isnt flipped ? sometimes i f i use flux and get sloppy with it i need to clean the board with alcohol . is it on perk , vero , breadboard ?
what power supply are you using ?
im learning , we'll thats what i keep telling myself
nono
Re: Circuit trouble
« Reply #2 on: March 30, 2013, 02:05:11 PM »
check for loose connections in the circuit
heew
Re: Circuit trouble
« Reply #3 on: April 09, 2013, 08:15:54 AM »
re check the soldering nods they might not perfect
Thecomedian
Re: Circuit trouble
« Reply #4 on: June 17, 2013, 07:55:18 AM »
make sure you dont have any wiring reversed.
If I can solve the problem for someone else, I've learned valuable skill and information that pays me back for helping someone else.
