Author Topic: Does not boost when using distortion effects.  (Read 11992 times)
jhferguson
« on: April 04, 2013, 03:30:08 PM »
Can anyone tell my why this pedal does not boost when I try and use a distortion effect on my multieffect pedal? When using a clean effect it boosts no problem and sounds really good but any type of distortion effect it will not boost. Any help is very appreciated!! Thanks again!!
wavley
Re: Does not boost when using distortion effects.
« Reply #1 on: April 04, 2013, 04:12:59 PM »
If you're using it before the distortion it's likely just making you clip more, try using it after the distortion and it will boost.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
aron
« Reply #2 on: April 04, 2013, 06:00:53 PM »
Yes, it's only making your input signal into the distortion bigger. Not affecting the output of the distortion as much.
Aron
jimilee
« Reply #3 on: April 05, 2013, 12:27:02 AM »
The other option I found useful was to put the boost in the effects loop and the distortion pedal in the chain to the input.
jhferguson
« Reply #4 on: April 08, 2013, 02:37:08 PM »
Unfortunately I am not cool enough to have an "effects loop" really. I basically have a multipedal (Fender Mustang Floor) and my little lead boost pedal and that is it...lol So go from my guitar into the boost and out of the boost into the multi-effects pedal out to the amp?
jhferguson
« Reply #5 on: April 08, 2013, 02:38:26 PM »
Wait, let me try again. From my guitar into the multi-effect pedal then out of there into the boost and then out to my amp correct?
tombaker
« Reply #6 on: April 08, 2013, 11:19:06 PM »
Yeah that's right, sounds like that's the problem.
Most multi FX pedals have some kind of compressor/limiter on the output, also something you can probably change, but if you're boosting the signal before the multi FX it's most likely just going to hit the compressor/limiter harder and not boost your overall level.
Blue Box, Harmonic Perculator, Brian May Treble Boost, Klon Vero, Fuzz Face Germ/Sili, Echo Base Delay, CS-3 Monte Allums Mod, JLM 1290 Mic Pres, JLM Mono Mic Pres, Engineer's Thumb, A/B/C & A/B boxes, Tiny Giant Amp, Microamp
jhferguson
« Reply #7 on: April 09, 2013, 11:45:43 AM »
Thank you everyone for your feedback and input!!
