Author Topic: Good Overdrive Preamp to pair with Engl High gain preamp  (Read 3250 times)
fretzburner
« on: April 07, 2013, 12:38:13 AM »
Hello, I need to build an overdrive preamp to pair with Engl or Black forest high gain build.Any recommendations? I'm looking at the model H type sound or similar,is it possible to add full tonestack to modelH and call it a preamp?
J0K3RX
Re: Good Overdrive Preamp to pair with Engl High gain preamp
« Reply #1 on: April 07, 2013, 02:40:14 AM »
Man, you want a lots o knobs huh? I am leaning towards a 1 knob treble booster type of some sort... Maybe a rangemaster or variant?
fretzburner
« Reply #2 on: April 07, 2013, 03:19:08 AM »
My application for this is not to push the Engl but act as second channel (engl off and od on) and still connected direct to power amp or fx return.connecting my modelH direct to PA seems lacking.
J0K3RX
« Reply #3 on: April 07, 2013, 05:01:03 AM »
Crunch channel? If you want a second channel maybe just add a second gain and volume on a stomp switch and set them at lower settings? The boost switch on the black forest, if setup correctly will act as lower and higher gain channels... You can aslo have a very good clean channel if you bypass Q1, Q2, and Q3 and connecting the first stage to the 5th stage, although the tone setting may not be optimal going from high gain to clean...
« Last Edit: April 07, 2013, 05:02:57 AM by J0K3RX »
fretzburner
« Reply #4 on: April 07, 2013, 05:27:19 AM »
Not really a crunch channel,but more on an OD sounding dirt for lead stuff which can be controlled by the guitars volume control.just like around the model H sound.If i can add full tonestack or bass treble tone on model H that will make it compatible as a preamp direct to power amp,i'll take this route.
ggedamed
« Reply #5 on: April 07, 2013, 09:17:46 AM »
Black Forest (or should I say Blacker Forest - I saw you modified its name, Jim) can go to quite clean if you lower the resistor between pin 1 of the GAIN pot and the ground. Or you can even replace it with a jumper to be able to use lower gain with any guitar.
Minds are like parachutes. They only function when they are open. (Sir James Dewar, Scientist, 1877-1925)
fretzburner
« Reply #6 on: April 07, 2013, 10:02:12 AM »
Maybe this also sacrifice the high gain capability. I need 2nd channel .I will try my modelH first in series with my engl and will just switch them one at a time(engl for heavy stuff and modelH for the rest).both are connected to the channel loop of my F1.Will be back after some test.
ggedamed
« Reply #7 on: April 07, 2013, 11:39:24 AM »
That resistor ONLY sets minimum gain level. Nothing else. It has nothing to do with the "high-gain capability".
« Last Edit: April 07, 2013, 11:41:11 AM by ggedamed »
fretzburner
« Reply #8 on: April 11, 2013, 12:47:57 AM »
Model H tested and sounds ok to me as lower gain od to pair with my engl build.Will use this setup for a while and evaluate.Thanks both of you high gainers jok3rx and ggedamed for some inputs.
