Help me solve this problem please, My turntable Denon DP-200 are weak signal since about a month ago. It happen when i was modify change it cable to canare and it can play normally for about 1-2 week then signal are low T-T . Its not low ever, it change in random time Normal>Low>Normal then back to low again.
I had check any cable closely and it all OK. Then coil is about 330 ohm,Maybe this OK? I think ok. My line phono are work fine normally. I dont know what happen with it now?
My turntable is Denon DP-200USB cartidge is MM, Or it cartidge Magnet are too old? It got this TT about 2 year ago.. I try to remove it cartidge and found only Pick-up and Magnet Rod, Sometime i put it back and sound back to normal then 1-2 day back to random Low and Normal...
Thank you
