Author Topic: **The DIYStompboxes 10-Year Anniversary Contest Thread**  (Read 355671 times)
Perrow
Re: **The DIYStompboxes 10-Year Anniversary Contest Thread**
« Reply #760 on: November 29, 2013, 11:54:44 AM »
lol, yeah , we can play hide n seek together.. ;D
What you said + why he's stuck at the embassy + your sausage obsession = too many yokes available for me to choose  :icon_mrgreen:
« Reply #761 on: February 13, 2016, 03:27:08 PM »
Maybe stupid question, but answer is appreciated: is it OK to use 4558 instad of TL072 in Orange Smothie?  :o
jimilee
« Reply #762 on: February 13, 2016, 03:52:30 PM »
In my experience and according to the data sheet, those two are completely interchangeable.
Jdansti
« Reply #763 on: February 13, 2016, 04:09:38 PM »
Welcome!
I think your accidentally posted your question in this old thread. It's best to start a new thread under "Building Your Own Stompbox" forum. Good luck!
GGBB
« Reply #764 on: February 13, 2016, 06:24:00 PM »
4558 will work just fine. In my testing, I found it to be just slightly noisier than the TL072, but otherwise performed equally.
Plexi
« Reply #765 on: November 01, 2017, 02:11:15 PM »
ok, here's my entry, its taken a while to design (too bloody long) and get the switching right with a little help from Ian (slacker) cheers man.  ;)
oh and a little help from mrs astronauts ideas on the etch design..... ::) ()trying to muscle in on it..)
introducing:
The ''SPACE PATROL FUZZ''
as you can see its basically a classic big muff with fat/thin switching, plus 3 other modes for synthy, buzzy, octavey, duck and swell type sounds..by switching diodes and collector resistors. (which was a pita to work out)
rather  like a bias control on a fuzz face...but for both collectors.
schematic:
pdf's:  layout + pcb.
https://dl.dropboxusercontent.com/u/7464107/SPACEPATROLFUZZLAYOUT.pdf
https://dl.dropboxusercontent.com/u/7464107/SPACEPATROLFUZZPCB.pdf
guts...the wiring was a lot neater, but i had to pull out the pcb and remake it, and had limited tinker time to get t finished on time.. :icon_redface:
video demo...dry then with effects..
 ;) enjoy...
p.s pedal backdrop coutersy of Mrs Astronauts dress....shhhhh... ;D
Old post bump!  ;D
Rob, can you re-upload the schematic??
Thanks!!
To you, buffered bypass sucks tone.
To me, it sucks my balls.
« Reply #766 on: November 02, 2017, 05:43:33 AM »
hi plexi,  sure..no problemo.  8)
https://www.dropbox.com/s/ek7odcm7qary2cz/SPACEFUZZSCHEMATIC.jpg?dl=0
i did eventually get around to making a PCB for this which is currently available on my site, with the rotary switch included.
all verified, can fit in a 1590BB portait or landscape orientation... ;)
https://deadastronaut.wixsite.com/effects/fuzz
Plexi
« Reply #767 on: November 02, 2017, 09:53:49 AM »
Thanks a LOT Rob..!
I would like to implementate your rotate switch to my Rams Head  ;D
Foxbat
« Reply #768 on: November 19, 2022, 04:59:47 PM »
Re upload of schematic please
Et voila.
Name of entrant: ~arph
Pedal name: Sentinel
A bit about the pedal:
This is a PT2399 based circuit, inspired by the Sewer Pipes Ring-Verb by Earthscum
I posted some sound samples way back in may 2011 and got some great reactions, but the pedal suffered from a little problem that never made me put out the schematic. The volume could get out of control. I did a five knob version with a volume control but still wasn't satisfied as it meant constantly tweaking the volume knob. Then recently Jon Patton came up (with the help of some forumites) with a way to limit the output of the PT2399 chip by using an LED to GND from pin 7.  This was ideal for this pedal and made me reopen the project.
So I present, the sentinel. A pitch modulator, delay (albeit very limited), sewer pipe reverb and drone verb sounds in a very small circuit.
It has four controls. Two are for modulation and two are for the delay.
1. Rate, the speed of modulation
2. Depth, the depth of the modulation effect
3. Drone, the feedback of the delay.
4. Width, the delay time of the circuit.
The key feature of this pedal in my eyes is the drone control combined with NO filtering in the feedback loop. This makes it possible to freeze notes, while you hear a drone sound in the back which pitch is determined by the delay time. (width). Because of this you can layer sounds and create complex mesmerizing soundscapes with just one pedal. It also does pitch pirate like sounds, crazy deep pitch modulation. Plus when the width control is set to minimum you'll have a sewer pipes like reverb sound.  Because of the limiter on the PT2399 the volume of the drone sound can not exceed a certain level, while the input CAN take higher levels. This way you can play clearly over the drone sound when you use a boosted input signal with the drone sound following your notes. The rest is up to the images and sounds. (don't mind my skills  :icon_redface: )
Schematic:  https://dl.dropboxusercontent.com/u/1849818/published_images/sentinel-contest.png
Layout I used: https://dl.dropboxusercontent.com/u/1849818/published_images/perf1.png
PLEASE NOTE: There is an error in the layout, don't use it. It is just for reference.
Images:
Yes, that is a lightbulb jumper  ;D
Video demo:
Thank you for your attention, may the best one win!
Arnoud
« Reply #769 on: November 19, 2022, 05:22:26 PM »
The fact this thread is alive again makes me notice the date on it - May 2013. Does this mean we'll get a 20TH anniversary contest next year? Should I start planning/scheming/panicking now?!?
puretube
puretube
« Reply #771 on: November 19, 2022, 05:56:41 PM »
Start with "panicking", first!  :icon_biggrin:
« Last Edit: November 19, 2022, 06:03:05 PM by puretube »
