DIY 9 Volt Power Supply Help
Started by HOTTUBES, May 25, 2013, 11:29:12 PM
HOTTUBES
I want to build a 9 Volt power supply that i can use on my workbench as well as my pedal board etc ...
This is what i have in spare parts laying around that i think i could use for the build :
1. Small Step Down Transformer @ 50 v/ac output
2. Three (3) 7809 voltage regulators .
3. Ten (10) 2.2K  ( .5) watt
4. Very good assortment of caps , diodes , LEds
5. Vero board
6. Five (5) 2.1 mm DC Output jacks
7. Large size hammond enclosure
Now i just need some guidance on building  it !!     :icon_confused:
Thanks for any help !
armdnrdy
I would say that the 50vac secondary transformer is out. Too much power to dissipate stepping it down to 9 volts.
You might want to think about building a supply with other available voltages as well since you are starting from scratch. This way you won't be limited to just 9 volts.
You can pay a $9 lunch-check with a $50 bill and expect $41 of change.
You normally will NOT want to "pay" a 9 Volt need with a 50 Volt supply, because you don't get "change", just heat.
Agree: find a 12V supply. Goodwill odd-warts shelf, or Radio Shed.
HOTTUBES
Makes sense !!
And the truth is i only need to power up 4 , 9 volt pedals , that are mostly dirt boxes that don't draw alot of mA .
I'll look around and see what i have ....
Will a 12 volt dc wall wart work here ? ( i think i have one of those )
HOTTUBES
So i checked my tickle trunk to find that i have 3 possible alternatives for power ...
Wall Warts
1. 12 Volts DC @ 1.0 amp
2. 12 Volts Dc @ 300 mA
3. 9 Volts DC @ 1.0 amp
Will any of these work for my intended purpose ?
Does it matter if they're  a " Dirty Power " source ?
armdnrdy
You can use the 12VDC 1 amp and do something like this:
http://www.muzique.com/images2/power4.gif
Use the input section and the section labeled: IC1-IC4
9 volt regulators in parallel. The filter caps at the front of the circuit coupled with the regulators should "clean" up the power.
The filter caps can be sized as big as your enclosure will allow. You can lay the caps horizontally if need be. Look to 470µf to 2200µf electrolytics for C6 & C7 cap values. C8 will be a .1µf poly film. The cap on the "load" side of the regulators can be 10 to 100µf.
HOTTUBES
Awesome  !!
Thanks Larry !
How many 2.1 mm outputs can i run with this ?
Could i run 2 off each 7809 reg. ?
My thinking is if you have 4 , 2.1 mm dc jacks with a draw no greater that 600 - 700 mA , i should be fine ???
HOTTUBES
Question about C6 - C7 caps ...
Does cap value matter here ?
Will a 1000 uf cap do the same filtering as the 2200 uf cap ?
50 volt rating i assume is good enough here ??
HOTTUBES
#8
Ok , Thanks to armdnrdy's ( Larry ) link , i was able to spin this up in the last while etc etc ....
I'm thinking that it should work just fine imo ....
I just put it on a small piece of vero i had sitting here ...
Wall wart voltage goes in to the board on left side , then the regulated 9 volts exits out the right side wires etc etc ...
Feel free to critique !!  ( i'm just a noob  )
Good noob reading: Power Supplies Basics at http://www.geofex.com/Article_Folders/Power-supplies/powersup.htm
Much more than a paint-by-the-numbers kit.
Jdansti
Nice job!  You might want to keep an eye (or finger) on the temperature of your regulators to see if you need heat sinks.
HOTTUBES
Quote from: Jdansti on May 26, 2013, 12:00:06 PM
Yes , good call , I was thinking the same thing ....
HOTTUBES
Thanks for everyone's help !!
I hooked up the wall wart ( source power ) last night to this little board , and checked it with my meter , it shows a perfect 9.05 v dc !!
But the true test will be how clean it sounds with guitar plugged in & playing !
I'm crossing my fingers !
armdnrdy
Quote from: HOTTUBES on May 26, 2013, 12:52:00 PM
If you are just powering 4 "dirt boxes" as you stated you shouldn't need heatsinks.
"the true test will be how clean it sounds with guitar plugged in & playing"
It all depends on proper filtering.
HOTTUBES
So , to take things one step further , i built this little DC power filter circuit to tag on the end ....
Roger Martin
May i know the schematics and BOM please?
Sounds promising  ;D
HOTTUBES
HOTTUBES
Henry89789
Hottubes: Thanks for the links. I was interested in the schematics and BOM also. I've seen the schematic for the regulator section before but it doesn't have the values for all the components.  I went to the web site from which it comes but couldn't find any info re: the component values. Can you provide the component values or tell where they come from? Thanks.
tommycataus
+1
As a newbie I'd be interested in getting a list of values for components for this project, been looking for a decent schematic for this project for some time! Thanks HOTTUBES
"Remember, there's a big difference between kneeling down and bending over." - FZ
