DIYstompboxes.com
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
|HOME|
|DIY FAQ|
|GEO FAQ|
|Debugging Page|
|Links|
|Schematics|
|Wiki|
|Layouts Gallery|
|STORE|
|AMPAGE|
|GEOFEX|
|AMZ|
Home
Help
Login
Register
DIYstompboxes.com
Projects
Diode-Compression Op Amp
Booster not working.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Booster not working. (Read 21061 times)
mattlee0037
member
Total likes: 0
on:
June 06, 2013, 11:36:23 PM »
So I have Baby Pink Booster effect using
http://tagboardeffects.blogspot.com/2013/03/bearfoot-baby-pink-booster.html
this schematic.
Right now when engaged there is a volume drop and the knob has no effect through the full sweep. When the SPST switch is in the position where the SW1 and SW2 wires are connected that is what happens and the volume either drops out completely or to a ridiculously low level in the other switch position.
I will add voltages tomorrow.
Bypassed it works fine and the LED lights up fine as well.
Logged
more
Awesome!
Total likes: 2578
quoll
Re: Booster not working.
Reply #1 on:
June 26, 2013, 10:47:41 AM »
so, a thread lost is now found.
before the crash, you showed us some voltages for the drain and source that were almost the same, no? and we said to check for shorts around those parts of yr board. any joy?
are you using the 2n5952 I saw on the mmolteratx schematic at
http://revolutiondeux.blogspot.com.au/2013/03/bearfoot-bjf-baby-pink-booster.html
? from the spec sheet, it might not bias right, so it seems an odd choice for this circuit.
Logged
"I'd like to be an angry prophet denouncing the hypocrisies of our time."
"the pub takes care of that for you".
mistahead
Awesome!
Total likes: 3
I don't have a shame gland... fortunately.
Reply #2 on:
June 27, 2013, 01:04:05 AM »
Hahah - I actually guessed the personal investment in helping out on this one would have you find it Ducky.
I think we were still debating the correct pinout on the trannies and confirming the soldering on the "top side" of the board...
Logged
more
Awesome!
Total likes: 2578
quoll
Reply #3 on:
June 28, 2013, 11:27:45 AM »
we were dabating the pinouts, and I lost but madstyne won, but that was on a different thread. watts, volts, degrees ......
and there is some progress there, less so here.
Logged
mattlee0037
member
Total likes: 0
Reply #4 on:
August 10, 2013, 11:47:43 PM »
To update you guys I found that they sent my the wrong transistor they sent me an n channel mosfet instead of a jfet or vice versa I can exactly remember, but it works now!
Logged
more
Awesome!
Total likes: 2578
quoll
Reply #5 on:
August 12, 2013, 11:14:52 AM »
that's fantastic. also, "bastards!" for the wrong sender of parts.
Logged
mattlee0037
member
Total likes: 0
Reply #6 on:
August 15, 2013, 05:27:07 PM »
Yeah, I'm just happy that I got it fixed
Logged
Print
Pages: [
1
Go Up
« previous
next »
DIYstompboxes.com
Projects
