Author Topic: Am i ordering right parts for npn boost?  (Read 10411 times)
gnort_2
« on: June 16, 2013, 02:28:53 PM »
Here are the parts im planning on ordering from mouser.  Are they the correct parts to make a NPN boost pedal?.  The amount of each component isnt listed, but i can figure out if i need to order one or two etc. on y own, just want to make sure its the right stuff.
http://www.mouser.com/Search/ProductDetail.aspx?R=110-Pvirtualkey69100000virtualkey691-110-P
http://www.mouser.com/Search/ProductDetail.aspx?R=233virtualkey53400000virtualkey534-233
http://www.mouser.com/Search/ProductDetail.aspx?R=DILB8P-223TLFvirtualkey64910000virtualkey649-DILB8P223TLF
http://www.mouser.com/Search/ProductDetail.aspx?R=3399virtualkey53400000virtualkey534-3399
http://www.mouser.com/Search/ProductDetail.aspx?R=NYS230virtualkey56810000virtualkey568-NYS230
http://www.mouser.com/Search/ProductDetail.aspx?R=RV24AF-40-15R1-B5K-3virtualkey14860000virtualkey31VQ305-F3
http://www.mouser.com/Search/ProductDetail.aspx?R=2N2222Avirtualkey51120000virtualkey511-2N2222A
http://www.mouser.com/Search/ProductDetail.aspx?R=271-100K-RCvirtualkey21980000virtualkey271-100K-RC
http://www.mouser.com/Search/ProductDetail.aspx?R=CMF5547K000FHEKvirtualkey61300000virtualkey71-CMF5547K000FHEK
http://www.mouser.com/Search/ProductDetail.aspx?R=271-10K-RCvirtualkey21980000virtualkey271-10K-RC
http://www.mouser.com/Search/ProductDetail.aspx?R=UST1C470MDD1TEvirtualkey64700000virtualkey647-UST1C470MDD1TE
http://www.mouser.com/Search/ProductDetail.aspx?R=UHE1H220MDDvirtualkey64700000virtualkey647-UHE1H220MDD
http://www.mouser.com/Search/ProductDetail.aspx?R=B41002A4106M000virtualkey59250000virtualkey871-B41002A4106M000
http://www.mouser.com/Search/ProductDetail.aspx?R=QYX2A104KTPvirtualkey64700000virtualkey647-QYX2A104KTP
In addition can someone tell me a good breadboard to order so i can test everything out before i assemble and solder them together?
I also have a hammond 1590b enclosure at home, i assume it will work well for this project.
aron
Re: Am i ordering right parts for npn boost?
« Reply #1 on: June 16, 2013, 04:15:44 PM »
The switch, pot type (should have regular solder lugs not pc mounted), breadboard - you want stripboard (available via the STORE link above). The resistors and capacitors are ok. You want a stereo jack (which you have) but also a mono jack for the output.
I see that I need to get the beginners kit going again.
gnort_2
« Reply #2 on: June 16, 2013, 06:24:28 PM »
@aron
     - I think you are saying that the switch i showed the link to would be ok? It seems to have the solder lugs (if im not mistaken) If not then what switch should i order?
     - Will a 1590b hammond enclosure do fine?
Thnaks for the help one and all.  Im gonna make this thing yet!
aron
« Reply #3 on: June 17, 2013, 05:19:19 PM »
You want a 3PDT switch. I would get the 1590BB to start with.
Check out this read:
http://www.diystompboxes.com/wiki/index.php?title=DIY_FAQ
gnort_2
« Reply #4 on: June 18, 2013, 12:22:02 AM »
Great link, read it a while ago but it was before what i know now so it made more sense this time.  Thanks many questions answered... (so many more to go)
Learning, learning, learning
gnort_2
« Reply #5 on: July 01, 2013, 05:25:20 PM »
didnt order led... Gah! the frustration...
gnort_2
« Reply #6 on: July 08, 2013, 06:49:34 PM »
What type of led with what ratings should I get?
mistahead
  • Total likes: 3
  • I don't have a shame gland... fortunately.
« Reply #7 on: July 08, 2013, 08:18:09 PM »
Cheap red LED's by the bulk pack.
Pick the size you like (I prefer 5mm).
gnort_2
« Reply #8 on: July 08, 2013, 09:13:12 PM »
Voltage rating doesn't matter?
How do I mount them?
mistahead
  • Total likes: 3
« Reply #9 on: July 08, 2013, 09:15:42 PM »
This is exactly what I have a bag of and have yet to run out:
http://www.jaycar.com.au/productView.asp?ID=ZD0150
There are bezel options for them, or actually a discussion about alternative mountings going on at the moment somewhere here.
gnort_2
« Reply #10 on: July 08, 2013, 09:49:23 PM »
What size resister should I use with one of these on the beginner project?
« Last Edit: July 08, 2013, 09:55:45 PM by gnort_2 »
mistahead
  • Total likes: 3
« Reply #11 on: July 08, 2013, 11:09:13 PM »
Beginner project is a 9V project?
The link I sent suggests a 330R for 9V supply - but try and see between that and 68K, resistors and LEDs are cheap learning experiences.
aron
« Reply #12 on: July 09, 2013, 01:57:45 PM »
Yes 9V.
gnort_2
« Reply #13 on: July 09, 2013, 04:25:58 PM »
Is stranded insulated wire ok for the input and output jacks?
Or do I need shielded wire?
mistahead
  • Total likes: 3
« Reply #14 on: July 09, 2013, 07:52:48 PM »
I use stranded copper twists recovered from my IT jobs/ventures (wake on lan/audio cables guys)  unless something gets noisy or goes "wrong". Then I use sheilded copper twists/shielded coax depending whats on hand/in which toolbox.
Solid core is great, till it breaks - then its a nightmare, I only use it on my breadboard.
