mxr noise gate debug help wanted
Started by peterg, August 25, 2013, 11:13:09 AM
peterg
I used the Tonepad Callate Gate 2 scheme and made mods to it. I'm not able to post a liink at this time.
Issues:
The sensitivity range is very limited from 0 to about 50k reiistance
Note attack is scratchy
The mods are based on some of the Tonepad suggestions, its build reports and various other right ups.
Mods:
1m resistor between Q3 gate and Ra resistor
Replaced Ra resistor with a 500k trimpot for release control. Set at 150k
Socketed IC1a's resistor and cap but hhave found the speceed values are best
Readings:
Ic 1 5.01
2 4.45
3 4.45
4 4.94
5 3.16
6 4.72
7 "
8 9.43
Q1 c 9.42
B 3.23
E 3.94
Q2 c 3.68
B 0.42
E 0.00
Q3 d 4.98
S "
G 3.68
The trannies are 194 and 196 hFE
My thought is to replace the 500k sensitivity pot with a 100k pot and a 400ish K resistor to deal with the range issue
Any suggestions?
http://www.tonepad.com/getFileInfo.asp?id=77
Assuming your meter is a heavy load; Not seeing a problem with voltages.
Did you use a tested board or is this your own layout?
DIMstompboxes
Maybe i'm wrong but that IC pin4 has 4.94v?
peterg
Quote from: PRR on August 26, 2013, 12:05:40 AM
Paul - thanks for the link. I created my own layout. The effect is there but I seem to be having the same issue as others have had relating to the sensitivity range pot. I socketed the resistor and cap at ICa -2 as recommended on build reports and will fiddle with them some more.
Quote from: stompbox on August 26, 2013, 02:37:06 AM
Good catch. I'll double check. I may have transcribed from my hand written note incorrectly - or I could have a bridge somewhere.
peterg
My IC - 4 reading was wrong - the beer googles must have been fogged up!
I used a 22k resistor and a 10uF cap at iC - 2 which solved the sens pot issue. The device works well except for a click with each note played. I take it that is the gate opening. I've tried a number of FETs and they all have the same issue.
Any ideas of how to get rid of the clicking?
DIMstompboxes
Mate, did you replaced the 1meg on Q3 gate with 1.8k?  That one in the middle of the three 1meg , the middle one try to replace it.
What FET did you use? There are many issue regarding this noisegate but don't give up, you're just at ballpark.
peterg
Quote from: DIMstompboxes on August 27, 2013, 02:35:56 AM
I replaced the 1m resistor with a 1.5K so the output is at the right level. No issues there. I used a 2N5486 FET. It's the closest to the recommended 2N5485 that I could find. I tried other FETs I have on hand and they all do the job (with clicking).
My 2N3904s aren't quite matched so there are some decay issues but that should be an easy fix.
Just need to get rid of the click.
The Noise Gate certainly is the most written up on pedal I've come across!
peterg
https://www.dropbox.com/s/yrxsusxrwjeefk0/1.jpg
https://www.dropbox.com/s/yrxsusxrwjeefk0/2.jpg
Attached are links to the front and back of the original MXR Nosie Gate.
The cap connected to the FET's drain is shown backwards on the schematic. The positive cap leg is connected to the drain.
I'll switch it tonight. Maybe that will solve the click problem.
DIMstompboxes
Yes try to reverse the cap neg to the drain.
For what I know if I'm correct  FET drain/source are interchangeable, but the schematic call for what it should be.
5952 need you to flip 180 degree I think, but yours is 5486..just try to reverse the cap polarity as you said maybe that it. give us an update mate.
